Results 1 to 4 of 4
Thread: E30 and thermostat / oil temperature
    Aug 2018
    France
    320i convertible 1990
    Hello,
    Especially in the winter time I observed that my oil gauge of my E30 (320i) just went a little bit above the minimum temperature position. In the summer time I used the car more times (it is a convertible) and the oil gauge went maximum to 25% of the maximum temperature position (about half way between the minimum and the middle position). I measured then the temperature of the oil tubes with a infrared temperature tool and it was about 84 °C.
    I already measured the electrical resistance of the two temperature sensors which showed "normal" results. I think the sensors are ok (but not 100% sure). Perhaps there is a problem with the oil thermostat as even when driving just 15min. also the coolant tube of the larger circuit is hot (which could mean that the thermostat is always open).
    Do anybody knows the oil temperatures when the oil gauge goes to the Minimum, middle and maximum position ?
    Any advices ?
    Best regards
    Wolfgang
    Aug 2018
    France
    Sorry it is the collant temperature and Not the oil temperature
    Coolant temperature
    May 2010
    Officially in Tampa
    87 Cabrio & 87 ETA
    The gauges are not very accurate but are more to monitor changes. 80c is the recommended tstat and if you are running close to that and have no obvious problems, you should be fine. Use your infrared gun on different parts of the radiator to see if parts of it are not circulating as well as other parts (a very common problem)
    87 Zinno Cabrio 98k Barn Find. Build thread http://www.r3vlimited.com/board/showthread.php?t=268987
    87 Lachsilber ETA Time Capsule. bought w 125k from 87yo original owner
    Cabrio deck lid & hinge struts (w sleeves) now for sale. See the link below for more info
    New "made in Europe" seat shocks. PM for details
    http://www.bimmerforums.com/forum/sh...ot-Seat-Shocks
    323i E30's Avatar
    323i E30 is offline ⅂!ʈө !ƨ l!ʞө ɐ ʇөlөbµouө
    Jan 2013
    Europe
    M52 E30 touring & E91
    Not sure about numbers, but the middle of the temp gauge (first to third mark) covers just a few degrees. Anything between there won't kill your engine.
    Typical E30 position of the needle is somewhat left of the middle mark, and usually won't pass it.
    This gauge is not buffered as opposed to newer cars, so it will travel a bit.
    ^ true story
    D̶i̶b̶s̶ ̶o̶n̶ ̶t̶h̶e̶ ̶E̶2̶1̶
  1. E30 M3 oil temperature gauge pegging.
    By Aaron Penkacik in forum 1983 - 1991 (E30)
    Last Post: 06-18-2014, 10:31 AM
  2. E30 e30 24v swap oil pan setup
    By hookenM in forum Engines, Performance Parts & Software
    Last Post: 01-29-2014, 05:48 PM
  3. BMS Low oil Temperature Thermostat
    By Guam135i in forum 1 Series & 2 Series (E81, E82, E87, E88, F20, F22, F23, F40, G42)
    Last Post: 05-21-2013, 06:37 PM
  4. E30 E30 325i/325e Oil Pan; Perfect, CLEAN, $125 + Shipping
    By Ben Carufel in forum E30 Parts Classifieds
    Last Post: 03-18-2009, 07:33 PM
  5. E30 FS: E30 325i/325e Oil Pan; Perfect, CLEAN, $125 + Shipping
    Last Post: 03-15-2009, 12:30 PM
