Results 1 to 16 of 16
Thread: Z3 won't start, no crank, no power windows
    Jun 2015
    Akron, Ohio
    2000 Z3 2.8L
    Today my Z3 wouldn't start and had to be towed home. When I try to start it all of the dashboard lights come on, but it doesn't crank. All of the electronics work except for the power windows. After I try to start it the oil and parking brake dashboard lights stay on, which is odd. I swapped the battery from another car and tied to jump it and the same thing happens. I don't think it's the battery.
    I checked the fuses and they are all good. Over the last few years, I have several related problems:
    1) One out of twenty times my key won't turn when trying to start the car. A little wiggle resolves this problem.
    2) The soft top open/close switches sometimes are wonky. I need to press the brake pedal several times for the switch to work (I think it's the brake switch)
    Any thoughts? Could it be a relay? Or my immobilizer?
    Dec 2013
    Chicagoland area
    EXOTICS
    Make sure the brake and starter interlock switches on the pedal assembly are not misaligned,
    causing the plungers to not depress, and also checking for clean,snug, electrical connections.
    Diagram here:https://www.realoem.com/bmw/enUS/sho...diagId=35_0252
    Jun 2015
    Akron, Ohio
    2000 Z3 2.8L
    I just check the alignment of both the brake light and clutch pedal switches. Both are aligned and push each button (white with a red collar) in and out correctly. When the soft top buttons don't work, my brake lights don't work as well. I've always assumed my brake light switch was going bad but it doesn't explain why the car won't start.
    Jan 2016
    Ca
    2001 525it
    Try another key your car has ews and if your key is really worn that could be why the ignition tumbler won't turn
    Dec 2013
    Chicagoland area
    EXOTICS
    You can test switch by disconnecting and removing switch,
    and checking resistance across the 2 contacts at the switch,
    while operating plunger, using a multimeter.
    Jun 2015
    Akron, Ohio
    2000 Z3 2.8L
    I thought about using another key as sometimes I have difficulties turning the key when unlocking the car door. Unfortunately, I have only one key. When I turn the key to the on position, the stereo, headlights, dome light, AC, blower fan, turn signal all work except for the power windows.
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    You can get a spare key from the dealer for around $70. It sounds like it's time
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Could be unrelated, but look for and check the fusible link in the trunk, near the battery (in one of the Big Cables). On a friend's '98 M Rdstr, it really had us scratching our heads when half the car had power and the rest of it__the part that makes it go__didn't.
    His had just corroded apart (immaculate, well kept Florida car all its life...)
    Jun 2015
    Akron, Ohio
    2000 Z3 2.8L
    I'll pickup a new key tomorrow and check the fusable link. Would the trunk wiring cause these problems? I repaired them last weekend and all of the wiring still looks fine.
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Great looking job. So you found that some wires were frayed or broken?
    I don't they would cause the dashboard and windows problems you mention in Post #1.
    BMW MOA 696, BMW CCA 1405
    Jun 2015
    Akron, Ohio
    2000 Z3 2.8L
    Quote Originally Posted by Vintage42 View Post
    Thanks. Yes, all but two were frayed.
    Jun 2015
    Akron, Ohio
    2000 Z3 2.8L
    Quote Originally Posted by jclausen View Post
    A new key will take a few days from dealer. Can I remove the ignition switch, insert the key into ignition (for EWS to be happy) and turn the ignition switch by hand with a screwdriver?
    Jun 2015
    Akron, Ohio
    2000 Z3 2.8L
    So I tried turning the ignition switch by hand while the key was turned in the ignition. Still no crank. I then checked the voltage on the positive jump post under the hood. It read 0 volts. The battery read 12.2 volts and my other car started fine when I put this battery in it. Maybe it is the fusable link. I guess I'll tear into these red cables.
    Aug 2017
    I'm not sure, but does a MY2000 have a battery safety terminal?
    Jun 2015
    Akron, Ohio
    2000 Z3 2.8L
    Quote Originally Posted by me77 View Post
    Yes, my car has a battery safety terminal that immediately runs into a 200 amp "mega" fuse. On a related note, my passenger's airbag light has been on since I bought the car 3 years ago.
    Jun 2015
    Akron, Ohio
    2000 Z3 2.8L
    Does anyone know where the other end of the BST connects in the Z3? Is it under the passenger's seat? I'd like to check for voltage and/or corrosion at this connection before I spend $250 on a new BST cable.
  1. Z3 Won't Start –*Buzzing Noise, No Crank
    By forestcasey in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-19-2018, 04:01 AM
  2. '94 ic won't start....will crank but won't fire
    By Melloyelloww in forum 1991 - 1999 (E36)
    Last Post: 05-24-2009, 05:54 PM
  3. car won't start or crank, part 2
    By plmuzikmaster in forum 1988 - 1996 (E34)
    Last Post: 12-12-2008, 11:44 AM
  4. car won't start or crank? battery tested....
    By Roffle Waffle in forum 1991 - 1999 (E36)
    Last Post: 02-20-2005, 04:39 PM
  5. Help - Z3 won't start?
    By MCoupeMike in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-09-2003, 06:35 PM
