Results 1 to 4 of 4
Thread: 2016 F30 foglight retrofit w/ full adaptive LED
    Jul 2014
    Montgomery AL Area
    2016 BMW 340i M-Sport
    I have a 2016 340i msport, with the full adaptive LED lighting package. I do not have front foglights at all.
    I'm moving to Belgium, and I've already prepped/modded my rear foglight switch, and have an appt to get that coded in under 2 days to be legal. (As well as the euro gps maps too)
    The thought occured to me..... "I wonder if the wires are already run to the front, and installing a set of front LED foglights (and grill surrounds) would be just as easy?"
    I haven't torn my car apart... but does anyone know if the wires are already run in my car? Can I just pop in a set of fogs/grills, trim the switch so it works, and then get it coded as well?
    Dec 2013
    Chicagoland area
    EXOTICS
    Get her up on a lift or crawl underneath the bumper and check if it's pre-wired for fogs.
    They should be easy to spot if fog lights were an option on your vehicle,and they were pre-wired.
    Jul 2014
    Montgomery AL Area
    I have an appointment to get the rear fogs coded tomorrow.... and my car goes on a boat headed for Belguim in 5 days.
    Was hoping there was someone that could definitively tell me whether or not my car was pre-wired for front fogs. No time to tear it apart right now.
    Jul 2014
    Montgomery AL Area
    Ok, so I found out from the company that codes BMWs that cars equipped with the msport package are NOT pre-wired for front foglights unless specifically ordered that way from the factory. Good to know.
    This is like the 5th question I've posted in this forum in the past 2 years.... none of them have any answers.... none. I ended up answering my own question through alternative research.
    Can anyone recommend a better BMW forum that actually has knowledgeable people, references, and is frequented more often? This forum is useless.
  1. BMW E38 adaptive LED headlight retrofit
    By RVAE34 in forum Lighting sponsored by BAVToys
    Last Post: 11-08-2020, 06:24 PM
  2. 5 series 2016 adaptive LED headlights condensation
    By Mexxedm in forum 2011-2016 (F10)
    Last Post: 03-02-2016, 11:35 PM
  3. Foglight Retrofit 01 to 00
    By VAMurph in forum 1996 - 2003 (E39)
    Last Post: 04-20-2009, 06:51 PM
  4. Foglight Retrofit
    By Laxpunk2006 in forum 1991 - 1999 (E36)
    Last Post: 10-22-2006, 04:13 PM
  5. Anyone ever retrofit e46 overhead shifter led's?
    By verserv in forum 1992 - 1999 M3 (E36)
    Last Post: 04-19-2006, 05:40 PM
