Results 1 to 3 of 3
    Aug 2018
    Athens Tennessee
    2011 BMW X6 50i twin V8
    2011 BMW X6 50i 4.4L V8 twin turbo
    What is the cylinder firing order for a 2911 BMW X6 50i 4.4L V8 twin turbo? I thought the order was:
    Front left- 1, 2, 3, 4 front being closer to radiator and back being towards firewall. Right side front to back - 5, 6, 7, 8. I have a cylinder 3 misfire and I want to ensure I change the correct ignition coil. I can’t get anyone from bmw service to call me back and answer my question. And google shows several different cylinder firing variations
    Aug 2009
    charlotte NC
    88 325 vert
    Quote Originally Posted by Jaypower37 View Post
    You need the location of cylinder number three the firing order is the order the cylinders fire in. They never fire 12345678 my old mustang firing order was 163524. Sorry don't know the cylinder location for you but it is probably not the same as the firing order.
    Stand in front of the car, facing it. Bank 1 is on the left side, Bank 2 is on the right side. 1 and 5 are closest to you, 4 and 8 are towards the firewall
    Swap it from cyl 3 to cyl 2 or 1. Clear the code and restart the car. If it comes back as cyl 3 you need to look at spark plugs or fueling (depending on other CELs, can determine what it is, or with ISTA). If the code follows the coil to wherever you moved it, replace the coil
  1. 2011 BMW X6 4.4L Starter Replacement
    By nsmutzer in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 01-19-2018, 07:14 PM
  2. K&N 33-2449 Drop in Performance Air Filter BMW X5 M/ X6 M 4.4L V8
    By gioioi in forum Engines, Performance Parts & Software
    Last Post: 11-16-2012, 09:32 PM
  3. 2011 BMW X6 xDrive35i $52,950
    By hannaimportsnc in forum X Series
    Last Post: 07-27-2012, 06:26 AM
  4. 2011 BMW X6 M - Alpine White/Black - WOW!
    By Global Autosports in forum X Series
    Last Post: 03-16-2012, 02:03 PM
  5. New BMW 4.4 V8 TWIN TURBO
    By mike87 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-26-2008, 09:46 PM
