Results 1 to 5 of 5
Thread: BCABLES Troubleshooting
    Apr 2014
    PA
    I purchased the Bcables setup with gts/DIS INPA etc. I can access the DME and EGS modules with little to no problem. I am having trouble connecting to the body modules. Won't connect to any. I am using the cable/software provided. 1999 750il. FWIW it has an ADS/OBD port. Can I access all modules from OBD port or some from ADS and some from OBD?
    "Helicopters: 10,0000 pieces of metal fatigue rotating around an oil leak."
    Apr 2014
    PA
    For anyone who finds this later, I fixed it by changing OBD to ADS in the edibas.ina file. I needed to do this as I have a 1999 750 with an ADS AND obd port. Most modules are not accessed through the obd port in this year car. Followed this vid
    Jul 2004
    Houston, TX
    36 Cylinders
    You shouldn't have to switch anything to ADS, just simply use your cable with the 20-pin adapter under the hood.
    ADS setting is for when using a specific ADS interface, which is totally different than that USB cable you are using.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Apr 2014
    PA
    Not sure why I had to change it, but as soon as I did what I described it worked immediately.
    May 2009
    palatine, IL
    528i
    Hi! Anyone have an issue with Bcables new ISTA+ where the instructions, procedures, and wiring diagrams do not pull up?
    Thanks in advance.
  1. Porsche Turbo Troubleshooting...
    By billycorgan in forum Off-Topic
    Last Post: 01-23-2003, 01:22 AM
  2. troubleshooting heating problem
    By boochaka in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-06-2002, 11:18 AM
  3. 1989 M3 Electrical Troubleshooting Manual free to a good home
    By pting in forum 1987 - 1991 M3 (E30)
    Last Post: 03-30-2002, 08:42 PM
  4. my car shakes badly now ! troubleshoot
    By Changster in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-28-2002, 11:07 AM
  5. Power mirror troubleshooting results and then some (m)
    By NormK in forum 1992 - 1999 M3 (E36)
    Last Post: 05-21-2001, 08:45 PM
