Results 1 to 9 of 9
Thread: Shaking car ?
    Jan 2016
    kingdom of saudi arabia
    BMW E23 745i A 85
    Question Shaking car ?
    Hi all
    My car is: 745i 85
    My car is shaking, So how can i balance to adjust the air, please enclose a picture of the location of air balance .
    thank you.
    [IMG][/IMG]
    Mar 2013
    USA
    E21/early e23/e34
    There's always members here to help but you really have to be more clear about the problem you're having-Reading it makes absoulitly no sense at all-
    Be more specific, where is the car shaking, is the steering wheel moving side to side when the car shakes, is it in the wheels or front of the car??? ...
    See what I mean?
    May 2013
    Killingworth, CT
    '84 733i, 01 X5 00 750iL
    Sounds like he is asking about the AFM idle CO mixture adjustment, which is an allen screw at a corner on the top of the AFM housing. Although this shouldn't need to be messed with. A suddenly rough running car probably has other issues.
    Steve H.
    Mar 2013
    USA
    E21/early e23/e34
    Quote Originally Posted by BONDOSPECIAL View Post
    Agree...
    Jan 2016
    BMW E23 745i A 85
    Thank you all for replying and I apologize for any misunderstanding.
    I will try to explain the issue in details.
    I’ve been having this issue for a week. Every time I start the car it shakes in idle. The whole car gets a severe shaking and It decreases when the car in motion or when I accelerate.
    Now my questions are:
    What would cause my car to vibrate or shake when idle? How to fix this issue?
    “BONDOSPECIAL”
    I would be very appreciated If you provide a picture that explains the location of the AFM. Maybe I can turn that screw and fix the issue.
    Thank you again
    [IMG][/IMG]
    Oct 2007
    Valley Village, CA
    1985 745i
    It sounds like you have a misfire. How mechanically knowledgeable are you?
    When your enemy is making a mistake, do not interrupt him.
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    I had an injector plug fall off my V90 once, shook like crazy at idle and dead misfire cruising...check there first. These old EV1 plugs turn to dust as time goes on. Any 745i that I rebuild receives all new ones.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    11/1984 735i (10:1-265/6)
    Jan 2016
    BMW E23 745i A 85
    Hi all,
    Sorry for being late due to holidays.
    I actually don't have any mechanical knowledge.
    Quote Originally Posted by yert315 View Post
    I remembered something. I washed the car engine and when the car in motion, it stopped and shut down and then I changed the fuel bump relay and it worked well. after a couple of days, the shaking returns. The injector plug is clean and I checked that.
    Quote Originally Posted by Hit Man X View Post
    [IMG][/IMG]
    Mar 2013
    USA
    E21/early e23/e34
    I've had engines do similar when power washing the engine, but it usually dried out overnight, and taking into consideration your location where it's HOT and dry it leaves me wondering- check your distributor cap and wires at the cap too, sounds like something may have gotten wet and if that's the case something could be loose lending itself to get wet. Loose plug wire, loose plug wire at a spark plug, loose distributor cap or wires...
    Make sense?
  1. Shaking car
    By SHAQ! in forum 1999 - 2006 (E46)
    Last Post: 01-11-2017, 05:06 PM
  2. Replies: 6
    Last Post: 07-18-2013, 04:24 PM
  3. Steering vibration, shaking car, and strange sound.
    By PeLtEuX in forum 1988 - 1994 (E32)
    Last Post: 04-22-2008, 06:40 PM
  4. my car shakes badly now ! troubleshoot
    By Changster in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-28-2002, 11:07 AM
  5. car shakes ... and grind gears in 3rd ?? help !!
    By Changster in forum 1992 - 1999 M3 (E36)
    Last Post: 09-03-2001, 06:55 PM
