Results 1 to 11 of 11
Thread: Jacking up your vechicle
    Mar 2017
    Lithuania
    1998 BMW 523i Sedan
    Hey guys, so I purchased a hydraulic jack (Silver 2.5T) finally! But an issue I have is how do I raise the front of the vechicle onto jack stands? I am familiar with special lift point at the front under the motor, but I can't fit my jack under the car even when jack itself is lowered, I can push it in by force but then I don't have room to pump it :/
    Išsiųsta naudojantis Redmi Note 4 Tapatalk 4 Lt
    Aug 2014
    Cheshire, CT
    1998 BMW 528i / 5
    You kinda need 2 jacks. Use the OEM at one of the front jack pads to get the car high enough for your hydraulic jack to fit. You can also run it up on ramps and then use the h-jack.
    Ed CT
    1998 528i
    5-Speed
    Aspen Silver
    Aubergine Leather
    Dec 2009
    Annapolis, MD, USA
    2012 JSW 2.5
    1. (Recommended) Return the jack and get a low profile floor jack. I use this one: https://www.jegs.com/i/JEGS/555/80077/10002/-1
    2. Drive it up onto ramps or boards to get the clearance you need to use the jack you have.
    3. Front only, jack from the side jack point and slide a jack stand under the brace that has the front center jack point and repeat for the other side.
    [IMG][/IMG]
    Mar 2017
    Lithuania
    1998 BMW 523i Sedan
    Good thought!
    Quote Originally Posted by Ed CT View Post
    Mar 2017
    Lithuania
    1998 BMW 523i Sedan
    Quote Originally Posted by JaxPlanet View Post
    The jack itself is already low, but still did not fit. I guess I can find even lower jacks, but I like the other points better, thank you!
    San Jose, CA
    1997 BMW 540i 6 speed
    The two-jack method works for me. I have a pair of Hein-Warners.
    Mar 2017
    Lithuania
    1998 BMW 523i Sedan
    Quote Originally Posted by edjack View Post
    But to be honest, the two jack method defeats the purpose doesnt it? You can fit the OEM one after you got it a bit up on jackstands
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    If I'm only jacking the front, I drive up on a small board under one front wheel, then slide jack in under the center jack spot. If I'm lifting the whole car, I jack the back first from the diff, then place jack stands under the rear rocker jacking pads. Then I jack the front via the center jack spot and then place the front jack stands.
    Mar 2017
    Lithuania
    1998 BMW 523i Sedan
    Quote Originally Posted by philly98540 View Post
    Haha, good idea, I wonder if one board is enough, what height is it? I only have two jack stands did not see much interest in all four
    May 2010
    Allentown, PA
    1997 528 Auto 03/'96 M52
    "is one board enough"... I can slide my jack under the front bumper, but there's not enough "swing" room for my jack handle to start engaging. I imagine a different jack might engage with less swing. Sort of like how some socket wrenches "click" in 10* or others in 6* (for example). In my case, one 2x4 under each front wheel is enough. Whether that's enough for you, or not... don't know. Only way to know is get off the 'puker and go try it out.
    Mar 2017
    Lithuania
    1998 BMW 523i Sedan
    Thats right, I can barely slide it but the room to pump it is not enough
    Quote Originally Posted by DennisG01 View Post
  1. E36 Jack Stand Recommendations
    By Rusty Chapman in forum 1991 - 1999 (E36)
    Last Post: 07-19-2001, 07:37 AM
  2. Best way to get 2 wheels on Jacks?
    By blu3m3 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-14-2001, 03:38 AM
  3. stock jack crumpled on me!!!!!!!!!
    By Anand in forum 1991 - 1999 (E36)
    Last Post: 05-06-2001, 10:36 PM
  4. Car Jacking
    By EricB in forum 1991 - 1999 (E36)
    Last Post: 04-16-2001, 06:41 PM
  5. Lincoln Jacks
    By tommymats in forum 1992 - 1999 M3 (E36)
    Last Post: 03-03-2001, 07:01 PM
