Results 1 to 8 of 8
Thread: Rough idle
    Jan 2016
    Troy, MO
    BMW 328i
    Rough idle
    My 1997 bmw e36 328ic m52b28 has had a rough idle for over a year now. I have replaced every single vaccine line under the intake I’ve replaced the pcv/ccv. I’ve cleaned the iac valve replaced both grommets on ccv and iac. I’ve replaced the intake gasket, throttle body gasket, valve cover gasket and the fuel injector o rings. I did replace the engine due to mine blowing up however I cannot seem to get rid of this idle it didn’t have it before I replaced the motor I have no idea what I could be. Can anyone help.
    Jun 2010
    NY
    1997 328i
    You sound like you did a good job vaccinating your engine lol.
    You could smoke test the system in case there is a leak you missed. Other things to do are servicing the injectors to make sure they are squirting equally, the service is usually pretty cheap. Replacing original ignition coils is the other important thing, there are a few aftermarket manufacturers but the longevity of them is unknown, the price however is excellent.
    https://www.ebay.com/itm/Set-of-6-Ig...7/262488221634
    You could also run a bottle or Royal Purple fuel system cleaner and drive the car a little harder. Also it wouldn't hurt to do a compression check.
    Jun 2013
    Houston, TX
    1997 328i
    +1 for ignition coils. I had the same issues for my 328 last year, and replaced the same things (minus the whole engine). I also got re-conditioned injectors, and it all helped a little, but the thing that fixed it for good was the ignition coils.
    Jan 2016
    Troy, MO
    BMW 328i
    Thank you both for the suggestions. I’ve been iffy on the whole smoke test thing due to not wanting to throw money at nothing. I honestly would have never thought of the whole injector thing I’ve considered the ignition coils/ coil packs just been hesitant because again money for no fix isn’t the best case scenario.
    Jun 2010
    NY
    1997 328i
    I've seen websites listing injector cleaning before but must have mis-read the cost, ~$25/injector is not at all worth it. If you really wanted to clean them you can buy an ultrasonic cleaner and watch youtube for some ideas on making your own cleaning rig. Also you can get a rebuild kit for ~$25 with new pintles/filters/o-rings/spacers. Just make sure you get the correct pintle caps, they have a larger orifice for the pink M52 injectors.
    Jul 2004
    Houston, TX
    36 Cylinders
    It's more likely to be a vacuum leak than anything else. There are good and small Chinese smoke machines on ebay for $120 and have loads of value.
    Fuel injectors possibly.
    Coils would manifest more at higher rpm with misfires especially.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Apr 2015
    Tennessee
    1998 BMW 328i
    If you suspect injectors, google Mepeh. He will rebuild them to like new condition for about $5 per injector. A smoke machine would also be a useful tool for diagnosis.
    Oct 2016
    Tenerife, Spain
    1997 BMW E36 323i
    Cool services that Mepeh offers.. I just googled him. And his prices are great too. Alas, he doesn't ship internationally, otherwise I would have bought a set 6 injectors for my 323i (same as 325i and US M3 3.0 injectors).. Only $68.60 dollar.. Very cheap. Rebuilt and flow-matched. And no down-time because you don't have to send your old injectors in. Also, what's nice is that he hand-picks the injectors so they are all flow-matched. If you look at the youtube videos below you sometimes see that even after servicing, the original set of injectors is not perfectly flow-matched (I think I see 10% differences here and there), which will cause significant AFR changes between the cylinders, which the DME can't compensate for with its two oxygen sensors (it would need six to compensate for that).
    Links: 323i/325i/US M3 S50 injectors and the 328i injectors (cost a little more, $98, but still real cheap)..
    And here are some great videos on youtube on how he cleans the injectors.. Some of the test results are shocking: https://www.youtube.com/channel/UCH-...view=0&sort=dd . You can only imagine the damage it might do to your engine/cylinders if (one of) your injectors are (is) bad.
    1997 E36 BMW 323i
    (European) 275k km (171k miles), with following small mods:
  1. Rough Idle Q's, and SF Stealers
    By C.Yang in forum 1992 - 1999 M3 (E36)
    Last Post: 08-14-2001, 03:26 AM
  2. Rough Idle
    By daytonflyer53 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-05-2001, 09:42 PM
  3. Help! Rough Idle
    By dakowals in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-04-2001, 11:35 PM
  4. Rough idle issue
    By jayhudson in forum 1992 - 1999 M3 (E36)
    Last Post: 05-15-2001, 11:04 PM
  5. Rough Idling
    By jaramill in forum 1992 - 1999 M3 (E36)
    Last Post: 04-13-2001, 10:10 AM
