Results 1 to 7 of 7
Thread: INPA: Working on a E36, not working on a E39
    Jan 2016
    Spain
    E39 530i
    I set up INPA last year for my 1996 328i, it works perfectly. Now Iīve bought a 2001 530i E39 and I want to read codes (ABS and TCS lights on, speedo doesnīt work). In ediabas.ini Iīve changed from Interface= ADS to Interface= STD:OBD, but then I got the message "IFH-0003: Datatransmission to interface disturbed".
    Iīve seen that in the folder C:\EDIABAS\HARDWARE, Iīve got only the folder "ADS", and I should have the folder "OBD" too, shouldnīt I? That means I have to reinstall INPA? I donīt remember having to choose between ADS or OBD interface when I installed INPA last year.
    Thanks!!
    Jul 2004
    Houston, TX
    36 Cylinders
    Are you using an actual ADS interface?
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jan 2016
    Spain
    E39 530i
    No, my car is a 2001 and only has a OBD2 interface. Iīm using a OBD2-USB, K+DCAN cable.
    Jul 2004
    Houston, TX
    36 Cylinders
    So for the E36 you are using the ADS interface then?
    Install an INPA/ediabas pack that has the OBD folder in the hardware folder, and run the obdsetup.exe file inside when you switch to K+DCAN.
    When you want to run ADS interface again, you will have to run ADSSetup.exe and restart computer. (And repeat to switch again)
    -Abel
    Jan 2016
    Spain
    E39 530i
    Well, Iīve installed another version of INPA, now I have the OBD folder. When I run INPA I see the battery and ignition lights ON so it seems that the laptop and car communicates properly, but I can only see the engine info (I can see analog and digital values, Vanos, engine error codes, etc..). I canīt see "chassis", "body", etc. info. When I select "chassis" and "ABS" (the one Iīm interested, because my ABS/TCS instrument cluster lights are on), it appears a error message: "IFH-0009: NO RESPONSE FROM CONTROLUNIT. Program will be stopped!"
    Iīve tried COM Port 1 and 4, reinstalled the K+DCAN interface drivers... but it seems strange that I can see the engine info and error codes, but not read the other car modules (I havenīt tried everyone of them, only ABS, airbag, instrument cluster...)
    Thanks a lot for your help.
    Jul 2004
    Houston, TX
    36 Cylinders
    Bridge pins 7&8 on the K+DCAN to gain dual K-line communication. (Also, use 20-pin port if you have it available)
    -Abel
    Jan 2016
    Spain
    E39 530i
    Ufff...so my K+DCAN isnīt fit for my 2001 E39 unless I bridge those pins...Iīm not very good at soldering. Those K+DCAN cables with a switch Iīve seen for sale, would they work like taking apart my cable and doing a bridge between pins 7 and 8? My car hasnīt the underbonnet 20 pin port.
    Thanks a lot, Iīm really grateful!
  1. E46 Control Arms on E36.... Not working...?
    By Press22 in forum Drifting
    Last Post: 09-24-2016, 02:29 AM
  2. Rear wiper not working (possibly motor), Aux not working, screen wash gone limp!!
    By N6PM in forum 1 Series & 2 Series (E81, E82, E87, E88, F20, F22, F23, F40, G42)
    Last Post: 08-26-2014, 05:04 PM
  3. A/C Doesnt work. ICE Cold is not working?
    By Thesonof in forum 1995 - 2001 (E38)
    Last Post: 05-17-2013, 07:43 AM
  4. WTB E36 not working gauge cluster
    By RoadRunnerCBR95 in forum BMW Parts Wanted
    Last Post: 07-24-2008, 05:02 PM
  5. Email notifications not working and Search "threads" not working
    By Seeker in forum Forum Software Questions & Suggestions
    Last Post: 05-27-2006, 10:46 AM
