Results 1 to 5 of 5
Thread: BMW E39 cluster pins
    Aug 2014
    estonia
    e36
    Hi
    Does anyone know insturment cluster BC - Borad computer signal pin ?
    I have with small display 2x 26pin connectors.
    I know how do power on cluster , but cant fint BC signal to change information like l/100km, milage left, clock and so on.
    can anyone help me ?
    Feb 2014
    Caboolture, Q, Australia
    E39 535i
    That information is stored in the OBC and relayed to the cluster.
    Sent from my G8141 using Tapatalk
    Aug 2014
    estonia
    e36
    What i need is change info l/100km, mialge left and so on , without bc button , but to do that i need to find that bc signal or something what triggers change. E46 i have found it but now i am looking for e39
    Los Gatos CA
    1987 325is, e34, Z3, e39
    It appears to be pin 5 on the blue connector. Only on the high cluster of course
    https://www.newtis.info/tisv2/a/en/e...isplay/nVEcF6L
    https://www.newtis.info/tisv2/a/en/e39-525i-tou/YyjQPp8
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    All you need is a MID or Nav screen. To change/set/reset/start/stop any of the OBC functions/features...is all done using the MID or Nav screen.
    Are you asking because the MID or Nav screen has been removed/replaced by and aftermarket audio unit? If so, you also removed the component that has the means to control your OBC.
    For example, if you have a high instrument cluster...you need a high MID or Nav screen and you can change the OBC from gallons/miles to liters/kilometers (see button circled in green below). You use the MID or Nav screen also to set the clock and reset the AVG MPG & MPH calculations:
    As you can see in the info below...the MID and Nav screen are simple input devices that are designed to control multiple components/systems that sends data to them:
  1. E39 BMW E39 or X5 Dash Cluster Gauge Trim Rings Chrome M5 Look
    By BMW112 in forum Interior Lighting & Body Parts
    Last Post: 08-15-2012, 06:16 PM
  2. E39 BMW e39 Gauge Cluster
    By RiegerD in forum Interior Lighting & Body Parts
    Last Post: 06-22-2011, 09:27 PM
  3. Bmw E39 M5 Instrument Cluster Speedometer For Sale 25k Miles
    By bmw540@rcn.com in forum BMW Parts For Sale
    Last Post: 03-07-2006, 07:41 PM
  4. BMW E39 Guage Cluster
    By rvancil in forum BMW Parts For Sale
    Last Post: 03-07-2006, 07:08 PM
  5. Bmw E39 M5 Instrument Cluster Speedometer For Sale 25k Miles
    Last Post: 02-10-2006, 10:32 AM
