RM European Auto Parts
Results 1 to 9 of 9
Thread: 1998 M3 5 Speed Sedan Blown Head
    Aug 2018
    North Jersey
    1998 M3 Sedan
    Hey Guys,
    So as the title says I have a blown head and am in need of a new one, now I would like to know how to go about this. I'm from north jersey and I am looking for a mechanic that does good work and is reputable. Additionally, I want to know what you guys think I should do. The car definitely needs a new head and I'm just trying to figure out if it would be worth it to redo the head as the car has 150k+ miles on it and I'm not looking to spend more than the car may be worth in the end. Thanks in advance for your input!
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Is your head gasket bad or are there issues with the head, valves, etc?
    88M3 AW 43k miles Project FS
    Aug 2018
    North Jersey
    1998 M3 Sedan
    There is an issue with the head itself, it definitely needs to be replaced.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    That won’t be cheap! You’ve got a few options:
    - buy a new head ($$$$$) and build it with new valves, springs, etc. ($$$$$$$$)
    - buy a used head ($$) with the risk that it’s damaged
    - buy a used engine.
    How was the head damaged? How badly damaged is the head. Is there damage to the engine?
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Chris Powell
    BMWCCA 274412
    Jan 2016
    Ca
    2001 525it
    put a used motor in it cheaper quicker
    Jan 2002
    Central Pacific
    If the head actually needs replacement, consider that you do not need an 'M3 head'' as the M52 and S52 heads are the same, besides springs and cams. Retainers, valves, trays and the head itself are the same. Check the E36 M3 sub forum for verification.
    The headache I see is sourcing a used head and find it to be warped or damaged as bad if not worse than the OP has now. It would be helpful to know the type and extent of damage to the existing head.
    Oct 2005
    Warwick, RI
    RECLAIMED! - 98 M3 Sedan
    I'm pretty sure I need to replace my head as well (98M3/4/5). I was looking around the e36 M3 sub-forum and found someone recommending http://www.autoheadperformance.com. According to their website, you can pick up a rebuilt head including a rebuilt VANOS unit for $815 + $100 core.
    I haven't done much research other than on BF.c, but i'm only reading good things. I'm likely going to source my replacement head from them or use them to repair mine. If you choose to look into them before I do, let me know how it works out!
    Hope that helps
    -edited for typo-
    Jan 2016
    Ca
    2001 525it
    Swap the whole engine out
  1. Purchase Input - 1997 M3 Sedan - Blown Head Gasket
    By dt3 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-12-2018, 08:13 PM
  2. FS: 1998 M3/4 Sedan - 5 Speed - 81K miles - CT
    By Asmod3us in forum 3 series & Z Series
    Last Post: 03-14-2008, 10:48 AM
  3. FS: 1998 M3/4 Sedan - 5 Speed - 79K miles - CT
    Last Post: 10-04-2007, 02:44 AM
  4. FS: 1998 M3/4 Sedan - 5 Speed
    By Asmod3us in forum BMW Cars For Sale / Wanted
    Last Post: 04-19-2007, 07:35 AM
  5. 1998 M3 Manual Sedan For sale in Bay Area!
    By Rocket Ghost in forum BMW Parts For Sale
    Last Post: 10-03-2001, 02:48 PM
