Results 1 to 11 of 11
Thread: Bad misfire - need some help here
    Jul 2012
    Yardley, PA
    98 M3/2/5
    Update 8/19 - problem has returned after new coil.
    Hey all,
    The other night I decided to pull my seats and pull up the carpet to dry out after some rain got into my driver-side footwell. This is what I did in order:
    - disconnected the battery
    - pulled seats
    - pulled up carpet to air out
    - Couldn't get the driver's footwell carpet area all the way up without pulling the throttle out
    - Pulled throttle and put back in few hours later
    - reconnected battery but did NOT put the top bracket on top of the battery to keep it in place (was only going for a test drive)
    Went out for a 10-20 min drive and did a WOT in third - everything felt great. A few minutes later at a stop light it started misfiring consistently through all RPMs out of nowhere. Pulled over and noticed the negative end on the battery connection was spotty (probably because I never fully seated the battery with the bracket and it could've been moving around slightly while driving). I'd try starting it and the car went black as soon as I tried to turn her over. Went back and reconnected the battery tightly and it started up but still had the misfire. The car spit codes for P1637 and a misfire on cylinder 5. I have not pulled the valve cover to inspect for loose rocker arm shims but plan on doing that tonight after I'm back from work. I've tried cleaned the sensors on the pedal and the front TPS to no avail. Also tried reconnecting the battery, etc. Every time I start it it starts with the misfire and does not change through any RPM (nor am I limited to any RPM).
    Could the spotty battery connection have fried something like the throttle actuator? Idk...
    I am stumped.
    TIA,
    Hank
    01/98 Porsche 996.1 911 - 2/6 - Current
    '03.5 M3 2/6 - Arizona bought - Wrecked 09/2018
    '06 WRX fully built/6 - Sold
    '95 323is/5 - Sold
    '95 325i/5 - Sold
    '01 540i/6 - Sold
    '03.5 M3 2/6 - Sold
    '02 M3 vert/6 - Sold
    '98 Cosmos M3/2/5 - Stg 2 AA Supercharged - Sold
    '98 M3/2/5 - Sold
    Dec 2013
    Chicagoland area
    EXOTICS
    Clear the codes,complete a short drive cycle,
    then perform a new scan for codes to confirm.
    Jul 2012
    Yardley, PA
    98 M3/2/5
    Quote Originally Posted by MIKYZZ4 View Post
    Already did that. Same codes. Misfire cylinder 5 and 1637. I have a feeling the misfire is causing 1637 so i picked up an ignition coil from VAC here in philly - throwing it in tonight to see if it changes.
    '95 323is/5 - Sold
    '95 325i/5 - Sold
    '01 540i/6 - Sold
    '03.5 M3 2/6 - Sold
    '98 M3/2/5 - Sold
    Jul 2012
    Yardley, PA
    98 M3/2/5
    Quote Originally Posted by hkovalcik View Post
    ​FIXED. ^^ Ignition coil #5 was the problem. Cheers.
    '95 323is/5 - Sold
    '95 325i/5 - Sold
    '01 540i/6 - Sold
    '03.5 M3 2/6 - Sold
    '98 M3/2/5 - Sold
    Dec 2013
    Chicagoland area
    EXOTICS
    Great, I enjoy when a simple scan leads directly to a simple repair or replacement.
    Jul 2012
    Yardley, PA
    98 M3/2/5
    Update - problem is back. Started misfiring again this morning (have driven roughly 100 miles since installing the new coil). I'm wondering if the rain has something to do with it. A good bit of it gets in my trunk because the taillight gaskets are shot. I had duct tape over the edges under the trunk to prevent water getting in but have since taken the tape off with the intention of doing it right and getting new gaskets. I've read horror stories about a misfire on cylinder 5 being a re-occurrence and the only solution seems to be a new DME.
    '95 323is/5 - Sold
    '95 325i/5 - Sold
    '01 540i/6 - Sold
    '03.5 M3 2/6 - Sold
    '98 M3/2/5 - Sold
    Dec 2013
    Chicagoland area
    EXOTICS
    Perform a compression test.
    Jul 2012
    Yardley, PA
    98 M3/2/5
    You think there's damage?
    '95 323is/5 - Sold
    '95 325i/5 - Sold
    '01 540i/6 - Sold
    '03.5 M3 2/6 - Sold
    '98 M3/2/5 - Sold
    Dec 2013
    Chicagoland area
    EXOTICS
    Well we're trying to confirm a fault that's specific to cyl#5.
    Jul 2012
    Yardley, PA
    98 M3/2/5
    I'll do a comp test but I don't think that'll give us much because I think she's healthy. I'm reading about the harness going bad and I'm wondering if that spotty battery from the first time I drove it wacked something like that. Regardless, at this point I'm going to replace all coils/plugs and do a comp test then. I'll report back with some results.
    '95 323is/5 - Sold
    '95 325i/5 - Sold
    '01 540i/6 - Sold
    '03.5 M3 2/6 - Sold
    '98 M3/2/5 - Sold
    Jul 2012
    Yardley, PA
    98 M3/2/5
    Replaced coil on cylinder 3. Everything is good, thanks. Misfire on cyl 5 was a misread since I had it unplugged
    '95 323is/5 - Sold
    '95 325i/5 - Sold
    '01 540i/6 - Sold
    '03.5 M3 2/6 - Sold
    '98 M3/2/5 - Sold
  1. 1997 Z3 2.8l P0302 code - misfire - need some help
    By markbritt in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 12-11-2011, 10:35 AM
  2. Engine misfire... need some help!
    By 69coupe in forum 1996 - 2003 (E39)
    Last Post: 09-07-2010, 06:51 PM
  3. If your CV joints have gone bad, I need your help
    By onewhippedpuppy in forum 1991 - 1999 (E36)
    Last Post: 06-13-2008, 11:27 AM
  4. Bad....bad day. Need some help/opinions (long)
    By ///2K in forum Forced Induction
    Last Post: 05-02-2007, 10:29 PM
  5. Paint in bad shape, need some help
    By BigFurryWhale in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 07-13-2006, 07:12 PM
