Results 1 to 14 of 14
Thread: Too Mount Manifold for Borg Warner Turbo
    Jan 2018
    Missouri
    1996 BMW E36 328is
    Top Mount Manifold for Borg Warner Turbo
    Looking to run the Borg Warner S366SX3 on a M52 stroker I’m building. However its kind of a bigger/bulkier turbo than most of its size, I’m in search of reccomendations for a top mount manifold that’ll let me run this turbo without cutting into my hood or engine bay underneath. Anybody know of one thatll make her fit?
    TX
    yes
    Good luck with that. Have you ever just set the turbo under the hood and looked at how much extra space there isn't?
    Apr 2006
    Minnesota eh?
    86 325es
    I think the rapid spool one is supposed to fit an S366.
    Jan 2018
    Missouri
    1996 BMW E36 328is
    I thought so too, but my buddy is running the rapid spool manifold with the s366, even asked before he bought it if it would fit, they shared pictures of it fitting and somebow his does not. Hits the hood still so I’m kindve just seeing if anybody on here has one they know fits before i start throwing cash around and risking it.
    Apr 2006
    Fall City ,Wa
    E36 Turbo, E39 M5
    I wonder if the test fir car has old sagging engine mounts, and some people have new poly ones could make up the difference I suppose.
    TX
    yes
    I considered many potential mounting solutions and ended up with running the S300 bottom mounted.
    Jun 2005
    south
    85 318i
    Quote Originally Posted by zr7685 View Post
    Out of the 100+ manifolds we have sold a few compressor housing on installs are touching the hood with the S366.
    It is a very tight fit considering you can maintain A/C, compressor housing measures 8-1/2" wide.
    My manifolds powering 8sec and over 1000rwp cars
    Home of the highest HP stock M30 in the world 550rwhp/622rwtq
    1/4 mile---> 9.81 @138 C4 Auto
    10.08 in car vid --->https://youtu.be/OiinFhUomjg
    Dyno vid... http://www.youtube.com/watch?v=C7aM7..._order&list=UL
    Mar 2006
    ATL
    E46 M3 Turbo 7675BB
    I run a top mount with a PPF manifold and 7675 turbo and I had to delete Ac !
    Toronto, Canada
    E36 Turbo
    RSI manifold in an E30 won't fit an S366 for sure... a 6262 Precision touches the hood as it is.
    Jan 2018
    Missouri
    1996 BMW E36 328is
    I’m also starting to think that the fitment issues may be related to the condition of the engine mounts in the car. I know aluminum tends to be a bit shorter in height but its more a street car than a track car and the vibration isnt a compromise I’m willing to make. However my buddy did have brand new oem mounts in the car when the turbo and manifold were i stalled. So that may be a contributing factor to the fitment issue. Anyone know if poly mounts are shorter in height?
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    polys should be same geometry
    and give/flex less than OEM type rubbers.
    Dec 2012
    Maryland, USA
    91 E30 m52 turbo
    im running a s363sxe, m52, e30, RSI manifold, condor delrin mounts
    it DOES clear the hood just barely but i had to raise the pass side of the engine like 1/4" for the exhaust housing to fit. Everything is super tight. I need to remove the turbo just to get the valve cover off as the compressor housing is so close to one of the nuts. The compressor housing is stupid close to runner #1 too so I heat wrapped it. If it wasnt so cheap, I would be running a different turbo.
    IMG_0460 by mitchlevy7, on Flickr
    Phoenix, AZ
    E36 M3/4/5 & E46 LSB M3
    I'm running a S366 and RSI Manifold and it seems to fit fine. Hood closes good.
    1997 BMW ///M3 - Estoril Sedan 5MT - M-Rain Interior (1 of 1)
    2001 BMW ///M3 - Laguna Seca Blue 6MT
    YouTube: (///Motorsport Throttle)
    https://www.youtube.com/channel/UCUM...pYSmibzy5YmUvQ
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    IMG_1736 by joe princen, on Flickr
    RSI s366 on both hoods, just massage the strut tower and send.
    or replace passenger side engine mount with rev shift and lightly sand down the top of compressor housing if you are having issues
    99 Turbo M3 - BWs366 - RSI - Fuse Fabrication - JE Cutring -
  1. Turbo Z3 with OBX Manifold and Borg Warner Build
    By Risen in forum Forced Induction
    Last Post: 07-20-2017, 02:17 PM
  2. Special V Band Flange for Borg Warner Turbo?
    Last Post: 09-29-2011, 01:31 PM
  3. Twin scroll Borg Warner turbos from Pontiac Soltice GXP (5 available)
    By EMC in forum Forced & Chemical Induction Parts
    Last Post: 01-10-2011, 04:23 PM
  4. Borg Warner turbo... too small?
    By naudlee in forum Forced Induction
    Last Post: 03-01-2010, 09:56 AM
  5. What's your opinions on Borg Warner turbos?
    By CeeP in forum Forced Induction
    Last Post: 10-15-2006, 07:47 AM
