Results 1 to 4 of 4
Thread: 325i break lining sensor light
    Aug 2018
    Fort Lauderdale, FL
    1989 BMW 325i
    I have replaced all rotors and pads and the both sensors yet the break lining light in red on the dash will not go out. Any ideas?
    Future Thanks Guys,
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    Not a BMW answer but no more red brake light. I couldn't figure it out, so I put black tape over the dash light.
    Later when I pulled the dash cluster, I pulled that light bulb. No need for such a useless sensor unless your...
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    I think I have read there is a solder issue on the mother board for the cluster having to do with that light. my son's car does it also. but you can unplug your pad sensors and see if it turns off. the other thing is it could be a spot in the brake pad wiring that is going to ground and making that light come on. like a spot where the wire got rubbed through
    No e30s again.
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    The circuit is pretty basic. It's just a big loop from the cluster and back. If anything in the loop either breaks or goes to ground, the light comes on. Early cars were prone to burning out a resistor on the cluster main circuit board. Even though you have an 89, it's possible that's your problem. There are other main board faults that can cause the same issue. Also, it's brakes and not breaks. In other words, if you don't use your brakes you'll likely find something else breaks.
    "Howdy, Folks!"
  1. "Check Break Linings" - How many wear sensors do I need?
    By Bimmmer740iL in forum 1995 - 2001 (E38)
    Last Post: 10-30-2010, 02:43 AM
  2. 1995 325i (E36) Brake pad sensor light
    By rghind in forum 1991 - 1999 (E36)
    Last Post: 10-04-2010, 10:32 PM
  3. brake line dash light sensor help
    By 85-318i in forum 1983 - 1991 (E30)
    Last Post: 07-26-2007, 03:09 PM
  4. 2001 325i brake pad sensor light?????
    By shovnan in forum 1999 - 2006 (E46)
    Last Post: 03-17-2006, 10:30 AM
  5. Break Lining light
    By John1984318i in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-16-2005, 07:02 PM
