Results 1 to 11 of 11
Thread: Ceramic exhaust manifolds
    Dec 2011
    Sydney, Australia
    2002 E39 Sportswagon
    Has anyone looked into or had their OEM cast iron exhaust manifolds ceramic coated?
    Street car. M54 530i. Looking to reduce under bonnet temperatures as well as any power gains.
    Worthwhile?
    Waste of time and effort?
    Not enough return for the dollars spent?
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    100% b.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    What problem are you trying solve? Temps hot under hood? No Kidding. Engines after 1990 are designed to run hot due to emissions. Engineering discovered/confirmed that high temps in a VERY controlled temp range allows NOX to be controlled and allows manufactures to meet Federal emissions standards on exhaust. End results: The thermostats are 195 degree, temps under hoods are hot hot hot, plastics and rubber parts deteriorate due to heat cycles, all of which lead to parts failures way down the road after warranty expires. Gee what insight! See DIY articles for lots of examples.
    As a DIY/Harry Home Owner you can approach this issue with one of two thoughts. 1. Reduce temps and impact engine designs/Emissions/Engine management designs. 2. Expel more heat faster - Open up the hood with vents as found on Carbon Fiber aftermarket hoods. At 15 years +++ why would you bother? Replace the impacted parts (once in the life of the average E39) and drive it.
    Oh, I would recommend replacing the hood pad/silencer as by now it is is full of dirt, dust, pollen and is more than likely ripped. $100 and it makes the under hood nice once again.
    Bottom Line: I agree with GG, WASTE OF TIME & $$
    Wait a minute you are located down under. Its WINTER down there. You want heat!! Up here we are cooking our toes alive just walking crossing the street!
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    JimLev's Avatar
    JimLev is online now Artifically Aspirated Moderator
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    I had my long tube headers ceramic coated inside and out. This keeps the exhaust heat inside the headers and is suppose to help speed up the flow and give a small increase in HP. I do notice the under hood temps are lower.
    You may just want to try wrapping them to reduce the heat emitted into the engine bay.
    Feb 2014
    Caboolture, Q, Australia
    E39 535i
    Winter here in Queensland Australia
    Granted it's a little cooler down in Sydney.
    That's about 87°F
    Sent from my G8141 using Tapatalk
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    There is a process called extrusion that I have done on on Chrysler big blocks to make the OE cast Iron manifolds look OE but flow more. Coating/wrapping will reduce the heat temps radiating from the parts but the value from doing it on a OE part vs a aftermarket header on a non race car are a looks cool and labor trade off.
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    Nov 2013
    Nashville,TN
    2000 BMW 540i
    if you have a blast cabinet and air compressor, this might be a (fairly) low buck alternative. I haven't used this product but I have coated a LOT of stuff myself. It's like most things involving a paint gun, prep is key. Techline also has some DIY coatings. If the manifolds are cast iron I wouldn't be afraid to wrap them. DEI has some wraparound shields that might work and the won't trap moisture as bad as the ~2" wide wrap.
    https://www.zycoat.com/zybar-color-coats/
    Jul 2011
    hillsborough n j
    2001 540i sport 6spd
    Have you considered having the inside of your muffler polished for additional flow?
    ~2001 540i/6speed~
    Schmiedman M5 headers, SPEC stage2+ kevlar clutch, JBR 11lb lightweight flywheel, ESS Tuning m60 manifold software tune, 3" SS freeflow OBX catback, afe cold air intake, m60 intake manifold, Cdv delete, powerflex urethane sway bar bushings, M5 rear sway bar ,Autozone replacement driver side blinker light bulb, 545 short shifter zhp weighted, "dsc off" sticker, m5 3.15 lsd differential, m5 chassis rods, akebono ceramic pads, G2 caliper epoxy, ecs braided lines, BC-Racing br-plus series w/swift springs 8/6~
    On the night that I go back in time, you will be shot by terrorists. Please take whatever precautions are necessary to prevent this terrible disaster.
    Sep 2013
    Tx.
    02 bmw 540
    Don’t forget the muffler bearings need to be regreased!
    Mar 2010
    Great LOLs in this thread. To be fair, if you had a disassembled motor or heads or WTF ever, and wanted to coat or wrap or whatever, sure... fine, might bring temps down a micro wiener amount and make your engine look kewlerz when you show it off at the local stroke and poke... but...
    Street car ass M54 and stone cold no other reason that the car is apart? Waste of time. (I wouldn’t ever think about extrude honing either.... just get some godammn headers for the thing!!! And THEN get em coated... that’s a well thought out not retarded plan...)
    2003 M3CicM6 TiAg
    Former:
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Quote Originally Posted by StRaNgEdAyS View Post
    That's about 87°F
    You should update your nav software from DOS to Mac OS 9
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
  1. E36 BMP Short Ceramic Coated Exhaust Manifolds M50 m52 s50 s52
    By yahh in forum Engines, Performance Parts & Software
    Last Post: 10-30-2018, 01:44 PM
  2. E36 BMP Short Ceramic Coated Exhaust Manifolds M50 m52 s50 s52
    Last Post: 04-17-2018, 10:23 AM
  3. Ceramic stock exhaust manifolds
    By rlaw1953 in forum 1983 - 1991 (E30)
    Last Post: 06-29-2013, 05:37 PM
  4. Ported & Ceramic Coated S50 exhaust manifolds
    By GotCone? in forum Engines, Performance Parts & Software
    Last Post: 02-08-2010, 07:33 PM
  5. Ceramic coated S50 exhaust manifolds
    By kdanielson in forum 1975 - 1983 (E21)
    Last Post: 08-30-2009, 10:13 PM
