Results 1 to 14 of 14
Thread: Does your ULF BT module sync contacts with iPhone?
    May 2018
    Boston
    E39 540i M-Sport
    Mine does not. I am using an iPhone X and have the Bluetooth setting for the the ULF set to sync.
    With this switch set to sync it seems to try to do something as the BT connection connects and drops over and over. Shutting sync down resolves this.
    I can live with it but was just curious if it’s my setup or just a matter of old technology not playing well with new.
    2018 M550ix|Carbon Black Dinan Stage 1|2003 540i|Jet Black|M-Sport
    Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi|
    Mar 2012
    London
    2000 728i; 2004 x3 3.0i;
    I had the same issue on Android after an update on a X3 2004. Swapping the ULF to a later 2007/8 sorted it. I do have to activate pairing using a laptop but once done you don't need to touch it. It didn't handle multiple phones too well, so I just use the phone for the main driver of that car.
    May 2018
    Boston
    E39 540i M-Sport
    Quote Originally Posted by osc911 View Post
    Thanks, good to know you had a similar issue, it's just bugging me even though I know from past experiences with early BT modules in my E65 that the ability to store and search through contacts using the car's interface is hoakey. I have also found that calls received and dialed from the phone do not store the recent call log. Again, all stuff I can live with because it is easier to actually go to the phone.
    Mar 2012
    London
    I've also had an earlier e65 and now a later e66. All glitches fixed with the last few module versions.
    May 2018
    Boston
    E39 540i M-Sport
    Yes, my F10 worked well. I am not going to upgrade for this issue though. It works fine for voice calls, just wanted to make sure I wasn't missing something. Would love to here from others too, especially with an iphone.
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    IME nadda ladda E39 guys have the ULF BT module.
    Some interesting version info here. Of course they're slinging gear so they'll err on the side of making it out to be a horror story but interesting story about the US dealers and seeing how many versions came out over time...
    https://store.bimmernav.com/blogs/in...mw-ulf-modules
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Los Angeles, CA
    Formerly 03' 540i
    I have about 3 ULFs (IIRC) from gen 3-5.
    All have worked with my SE (newest IOS). Though some tend to put up a fight when entering the pair code.
    If you JUST finished pairing the phone, you may have to turn off the car and exit pairing mode for the list to sync.
    When you turn the ignition back on, just make sure it's still paired and it should begin syncing.
    2003 BMW 540i [Sterling Gray / Gray]
    [Msport] [Mods from A-Z] [Two-Tone Interior]
    Stuff For Sale :
    All types of E39 OEM Used HVAC Buttons
    Other E39 Parts, see my ebay! [Click]
    May 2018
    Boston
    E39 540i M-Sport
    Quote Originally Posted by Dking078 View Post
    Thanks, I have done all this a few times. I don't have an issue with pairing, I just don't get any contacts on the cars system. There is no sync or address book download. It is all in the cloud though which I just thought of while typing this DOH!, I bet that's it.
    Apr 2014
    Renton, WA
    03 540i, 04 X3, 00 328i
    With one of my previous phones the contacts list did not get automatically transferred to the ULF. However, the ULF accepted the bluetooth contacts transfer immediately after the initial pairing process if it was done manually from the phone. Not sure how to do this with an iphone though.
    Los Angeles, CA
    Formerly 03' 540i
    Quote Originally Posted by Joe///540i View Post
    I bet it's that. These systems likely take info on the phones internal drive.
    Clouds were clouds back in the early 00's XD
    Stuff For Sale :
    Mar 2010
    Actually not many people know this but SIM chips themselves support recording and storing an address-book/contact-list. On old phones there'd be various options to choose the internal or SIM contact list and to trigger a copy / sync between the 'native' contact list w/ the SIM card, the idea being when you swap your SIM around you always have your contacts updated and with it. That's long since stopped being used by modern phones AFAIK (been out of the biz for a LONG time...) but perhaps the early revs of the ULF did something that explicitly looked for the SIM-contacts...
    2003 M3CicM6 TiAg
    Former:
    Philadelphia, PA
    2005 M3 & 2004 330i
    It’s been a little while since I’ve had a ULF, but my contacts did transfer over. Might have to go into the Bluetooth settings on the phone and enable contact sharing.
    May 2018
    Boston
    E39 540i M-Sport
    I tried it again yesterday, this time flipping the sync switch on the ULF entry in Bluetooth and just checked off favorites and recents. No luck. In addition, when I turn on contacts sync it really messes with my Bluetooth connections. They drop, connect, drop, connect...repeatedly. Obviously the phone is trying to sync and it's getting shut down.
    All good though, I like the voice integration.
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    I find the old voice control system to be entertaining
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
  1. ulf bluetooth module
    By coldwell in forum BMW Parts Wanted
    Last Post: 12-02-2009, 02:47 PM
  2. Replies: 6
    Last Post: 09-15-2009, 03:22 PM
  3. Does a stereo bluetooth module exist?
    By Lenaxia in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 08-29-2009, 06:07 PM
  4. does tire weight offset larger tire contact patch?
    By jkwilson in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 07-31-2006, 04:57 PM
  5. How long does it take to re-sync EWS? ESS 530i
    By Coop in forum Forced Induction
    Last Post: 12-24-2002, 03:17 PM
