Results 1 to 7 of 7
Thread: 2002 325i airbag light
    Aug 2018
    DC
    2002 325i
    Guys..sorry to make this my 1st post but I'm stuck and thinking what's next step on this issue...Currently have airbag light on 2002 325i.......i have a code (02 Belt Tensioner, Driver) and when I reset it, it immediately jumps to another code (04 Airbag, Passenger, stage 1). I changed out the tensioner and wiring back to the wire that goes under the carpet. I also took out cleaned the wires that goes to the airbag in the passenger door. Any thoughts on where the problem is?
    Thanks.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    What tool are you using to clear the code? How old is the car’s battery? Are you having any other electrical or electronic isssues?
    Aug 2018
    DC
    2002 325i
    Can't remember the name of the scan tool but I picked it up on Ebay. It's definitely clearing the fault because the light goes off for a quick second and then comes back on again. No other electrical issues, everything works right. The car battery is a bit older but working well.
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by brownrice78 View Post
    Thanks.
    Code 04 is for the passenger airbag above the glovebox, not side airbag.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jan 2014
    USA
    04 ZHP, 83 320i, 00 M5
    More than likely your seat occupancy sensor is bad on your passenger seat or you have an issue with the electrical connection to it.
    Cheap fix is to search on eBay for a bypass.
    _________
    1980 320i - Kashmir Metallic - Sold in 1993
    1985 535i - Cosmosblau Metallic - Sold in 1995
    1985 535i - 1985-06 - Delphin Metallic - Sold in 2016
    1983 320i - 1982-09 - Kashmir Metallic - Currently own!
    2004 ZHP - 2003-08 - Titanium Metallic - Currently own!
    2000 M5 - 2000-02 Titanium Silver - Currently own!
    Jul 2004
    Houston, TX
    36 Cylinders
    A bad seat occupancy sensor would throw seat occupancy codes.
    -Abel
    Aug 2018
    DC
    2002 325i
    i actually tired using a Ebay bypass on the passenger side but that didn't do anything. I figured it was a small investment..so why not...didn't do anything.
  1. 2002 325i tail light harness
    By GATORSHOES in forum 1999 - 2006 (E46)
    Last Post: 03-11-2016, 02:13 PM
  2. 2002 325i brake light,abs light and antilock brake lights are on
    By skilletdog in forum 1999 - 2006 (E46)
    Last Post: 02-02-2013, 10:55 PM
  3. 2004 325i airbag light
    By Jennifer82578 in forum 1999 - 2006 (E46)
    Last Post: 05-21-2011, 06:56 AM
  4. 95 325i - airbag light keeps comming on?
    By PHARO in forum 1991 - 1999 (E36)
    Last Post: 09-11-2005, 11:35 PM
  5. 2002 325iS Fog Light bulb replacement
    By ChrisS00 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-24-2003, 02:51 PM
