Results 1 to 4 of 4
Thread: Odd O2 Behavior
    Nov 2005
    Atlanta, GA
    1995 M3
    Odd O2 Behavior
    Fellas,
    Question about my 1995 M3. I'm getting a weird Check Engine light coming on intermittently. To start, the car runs great, strong without issue. Occasionally, usually when sitting at a stoplight, the idle will drop from a nice ~800rpm down to ~300rpm, stutter, then completely go back to normal. This throws a Check Engine light.
    I read the code from my Peake and I get: FF C9 0D: o2 sensor.
    This isn't super surprising, as the car has 170,000 miles and this is the original. So I replaced the 02 sensor... and the issue persists.
    Before I go throwing a bunch of parts at this issue, does anyone have any obvious things I should check?
    Thanks,
    E
    Evan Ruff, Engineer, Atlanta GA
    1964 Cadillac Coupe De Ville
    1970 Ford F100 Ranger XLT
    1972 BMW 3.0CS, converted to 3.5L w/L Jet
    1978 Ferrari 308GTB
    1985 BMW M635CSi
    1995 BMW M3
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    guessing the O2 sensor code is due to other issues, like fueling or another sensor. Whatever the issue is causes the hiccup (lean, rich, whatever), then DME complains that O2 is not correct reading.
    Really a lot of things it could be … quick suggestion: ICV dirty or faulty?
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
    Nov 2005
    Atlanta, GA
    1995 M3
    @ScotcH, ICV is kinda what I was thinking. I can't recall the last time I cleaned it out. The weird thing, is I thought the O2 code threw only after 10 seconds of inconsistent reading. Also, it will clear sometimes after a minute.
    1978 Ferrari 308GTB
    1985 BMW M635CSi
    1995 BMW M3
    Nov 2010
    Whidbey Island, WA
    1998 Techno M3 Coupe
    Small vacuum leak causing you to run too lean at low rpm?
  1. Odd ABS Behavior (2000 E39 528i)
    By srhorn in forum 1996 - 2003 (E39)
    Last Post: 06-09-2008, 08:24 PM
  2. New X3 owner odd vehicle behaviors
    By serge911 in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 02-22-2008, 06:00 PM
  3. New 335xi owner. Odd breaking behavior?
    By adrian1480 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 07-22-2007, 02:47 PM
  4. Odd Cop Behavior
    By Deloriant in forum BMW Rides & Events
    Last Post: 04-26-2007, 07:08 PM
  5. 94 325i odd stereo behavior
    By Gandaalf in forum 1991 - 1999 (E36)
    Last Post: 07-16-2005, 11:30 PM
