Just as title says. I pulled in the garage after driving 60 miles in heavy rain when I notice water drips from the roof at the back of each rear door area. Leaking from same spot on both sides. To be exact on the location, the water drips were landing on the outer seat belt buckle.
Never happened before. Is this a clogged moonroof drain?
2001 BMW 740i - Anthracite Gray - Style 32 Wheels --------- 2004 BMW 330i - Silver Grey Metallic
Convenience Pkg - Cold Weather Pkg - PDC ------------------- Sport Package - Auto - Mroof - Hseats
It is - time to break out the weed-whacker line!
My BMW Repair YouTube Channel
The drain hose may have separated from the sunroof cassette. It may be time to drop the headliner, push the hose back and put a clamp or zip tie on it.
-Messan
The above is my 2 cents. Take it or leave it.
01 Shorty Sporty BLK/BLK
The headliner was just re-covered recently, maybe another data point to check the hose connection, before the edger line gets used.
Update:
I lowered the rear of the headliner and found that both the rear hoses were disconnected at the back. I doubled zip-tied the hoses back on. But before I was done I had to deal with the water that was under the seat, it was soaked up by the spongy cover material covering the body panel. I had to get everything dry, so I gained access enough to get a small fan to blow air underneath the spongy covering and let it blow for a couple days on each side until it was good and dry.
Everybody jumps to clogged line but there are FOUR lines that drain the cassette and any one of them can shrink short and pop off due to the high roof heat. Any new E38 owner should pull the headliner first and glue / clamp them up. Careful with clamps, you can crack brittle plastic.
---- Processing Individual ----
Z1XX Upholstery
Seats front and back in Epingle / leather englishgruen,
As Schl.Nr. B9EG.
Front seat backrest in Montana Englishgruen (No. 8 174 861)
Other interior equipment as for Volleder Nappa englischgruen,
Schl.Nr. P5EG
Would a disconnected rear roof drain leak into the trunk? Anyone with a picture of the roof and routing with the headliner removed? I've got a wet trunk but the cabin is dry. The car has been stored outside under a car cover so there is no risk of tree debris. My roof panel is starting to show some rust spots at the edges so I'm going to replace it anyway.
--Ken
TRPCHGE - '01 740i Black/Black 230k'ish - Power folding mirrors, Mk.IV Nav, 16:9, M-pars, Sport seats, Sport wheel, Steptronic, Euro rear fog switch, 2.50" X-Pipe, Shadowline, E53 4.6is Cluster, Lacewood interior, Chromeline, 3.15, Bilstein B6+H&R Stage II's. - SOLD 06/21
BSKCASE - '98 740il Arctic Silver/Black 175k'ish - Face-lifted, 3" Projectors, Shadowline, 01 Tails, Hydro Trunk, Sunshades, 750il Full interior retrofit, Sport Seats, Steptronic, Face-lift Steering Column, X5 Steering wheel, E53 4.6is Cluster, Euro E66 Piano black/Chrome Grab-handles, Chromeline, Suede Pillars/Headliner, Auto wipers/Lights, Lighted Handles interior/Exterior, Dual battery retrofit.
WIP: Custom Style 42 18x9.5" ET12, 18x10.5" ET8, 3.15 LSD Rear diff.
