Results 1 to 2 of 2
Thread: Blower Motor not running
    May 2017
    Mb, Canada
    1998 BMW 328ic
    Hi All! My 1998 328i vert heating cooling blower motor (not the aux fan) does not work. I have full indications on the bar graph for temperature and the + - buttons seem to work ok. I haven't used the fan at all for about three months but it was working great the last time I used it. I checked the fuse late last night, but only visually.
    Any pointers on this fix?
    I am thinking:
    -swap out the relays for the horn (R4) with the heater blower (R9)
    -check the fuse with the multitester
    After that I'm not sure but maybe check the relay and fuse connections?
    Thanks for any help, I will try the above and any suggestions that I receive tonight. Hopefully this isn't another in-depth repair.
    Don B.
    May 2017
    Mb, Canada
    1998 BMW 328ic
    So I removed the resistor inside the cabin and hot wired the fan with the leads and the fan does run well so I would guess the resistor is shot. The relay itself was working as I swapped it out with the horn relay and the horn worked.
    I ordered a Rein replacement so hopefully that'll do her.
    Don B.
  1. E46 Blower Motor not running.
    By Andre325 in forum 1999 - 2006 (E46)
    Last Post: 02-07-2010, 02:11 AM
  2. blower motor not working....
    By BIMMERKILLA in forum 1996 - 2003 (E39)
    Last Post: 10-18-2006, 12:06 AM
  3. Blower motor not working
    By Redgz71 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-14-2005, 12:15 AM
  4. Blower motor keeps running after shutting car off?
    By Newbomb Turk in forum 1999 - 2006 (E46)
    Last Post: 04-18-2005, 01:53 PM
  5. HELP! Blower motor not responding to controls
    By beeman in forum 1991 - 1999 (E36)
    Last Post: 02-23-2005, 09:36 PM
