Results 1 to 11 of 11
Thread: Intermittent Dash Light Trifecta
    Oct 2007
    Studio City, CA
    2007 328i E92
    It's been really HOT in LA lately, and I'm experiencing some fallout from the heat. The door-lock module is sometimes being a PITA (responds late to key fob, etc.), but my main concern is that I'm getting random, intermittent trifecta lights on the dash.
    Here's the scenario - 2002 325iT, 161K miles:
    That hard-braking situation, where the ABS kicks in and the pedal feels like the brakes are *grinding* - I get the trifecta;
    In the heat, just common low-speed braking will sometimes throw the lights on (along with the audible *beep*);
    I have no other symptoms of brake fading, or the car running poorly at all. In all of these instances, after turning the car off and restarting it, the lights all go out after half a minute or so. I have no way to plug in code-reading software, so not sure what to think of replacing. What do you think? Is it a wheel speed sensor? Failing ABS unit?
    Mar 2010
    Fredericksburg VA
    '00 328Ci, '18 330xi
    Front wheel speed sensor. Pull it out, clean it, put it back in.
    Jul 2004
    Houston, TX
    36 Cylinders
    You MUST scan it, anything else is a guess, which will have you spending more money by shotgunning parts.
    It can be any of the wheel speed sensors, the yaw sensor, lateral acceleration sensor, or the module itself.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Oct 2007
    Studio City, CA
    2007 328i E92
    I agree, and I may get to that point. But I'll try cleaning the sensor(s) first, as mdfiasco suggested above - easy and free. I have an indie BMW wrench who can scan it if/when necessary. My hesitation with that is that the problem is intermittent. Perhaps a scan will still show the problem, but I wanted to try cheap/free suggestions first.
    Thanks, guys.
    Dec 2013
    Chicagoland area
    EXOTICS
    Exactly why a scan should be the first attempt at diagnosis,
    as the error codes are stored.
    Jan 2014
    USA
    04 ZHP, 83 320i, 00 M5
    You can take your car to autozone and scan it for free.
    They will scan your car at no cost to to you.
    _________
    1980 320i - Kashmir Metallic - Sold in 1993
    1985 535i - Cosmosblau Metallic - Sold in 1995
    1985 535i - 1985-06 - Delphin Metallic - Sold in 2016
    1983 320i - 1982-09 - Kashmir Metallic - Currently own!
    2004 ZHP - 2003-08 - Titanium Metallic - Currently own!
    2000 M5 - 2000-02 Titanium Silver - Currently own!
    Mar 2010
    Fredericksburg VA
    YMMV, but I've never had a bad wheel sensor show up in a standard OBDII scan... MIKYZZ4, are you talking about a more in depth laptop software or something?
    Dec 2013
    Chicagoland area
    EXOTICS
    Yes, a generic OBD2 scan tool can not communicate with all the BMW systems modules,
    you'll need a BMW specific scantool/software to retrieve the stored codes.
    annapolis, md
    e46, e39
    Scan tool for ABS
    I don't know if you've solved your problem yet. The Creator C110 Scan Tool will read the ABS module and individual sensors (through the module). If it indicates that it can't communicate with the ABS module at all, the module is probably bad. Not uncommon. Wire bonds or solder bonds get loose. The failure is often intermittent.
    The C110 costs less than $50. It's available on Amazon and other places. Various firmware versions are offered. Ver 4.4 worked on my 2000 E39.
    Oct 2007
    Studio City, CA
    2007 328i E92
    Quote Originally Posted by danzee View Post
    Great recommendation. Thanks.
    Dec 2013
    Chicagoland area
    EXOTICS
    Yes co$t$ more, but contains an array of functions besides just reading/clearing codes:http://www.foxwelltool.com/wholesale...installed.html
    Scroll down for all the features and functions.
  1. Intermittent light trifecta... ABS, BRAKE, DSC
    By Fuddy in forum 1996 - 2003 (E39)
    Last Post: 01-13-2014, 12:19 PM
  2. DSC & ABS dash lights turn on intermittently
    By nitsuga in forum 1996 - 2003 (E39)
    Last Post: 03-05-2010, 12:08 AM
  3. Intermittent dash lights problem '99 e46 323i
    By Tempest in forum 1999 - 2006 (E46)
    Last Post: 09-19-2009, 01:12 PM
  4. Intermittent Dash Lights
    By sml in forum 1995 - 2001 (E38)
    Last Post: 01-01-2009, 08:08 PM
  5. dash light complications???
    By T///MW in forum 1992 - 1999 M3 (E36)
    Last Post: 08-23-2001, 08:59 AM
