When I start the car and put in reverse, the Traction Control + Brake and ABS lights come on, drive it, the light goes off after a minute or two, the car drives normally.
anyone on the forum can help what causing the light to comes on.
Thanks,
David
Restart the car a few times and the Traction-Control-Brake-ABS light are Off.
CEL is on, Fault codes is showing P0740 - Torque Converter Clutch Circuit. The car drives normal.
Cleared the code twice.
How can I troubleshoot the P0740 error?
Also, just replaced the trans fluid/filter few weeks ago.
Thanks,
2001 750iL
