Results 1 to 6 of 6
Thread: 2008 535i rotor issue
    Aug 2018
    Raleigh, NC
    2008 BMW 535i
    Was trying to change brakes and rotors on a 2008 535i. pads no issue but when I tried to get the rotors off (after removing the screw) they were stuck on. I didn't think this year had electric parking brake and the manual parking brake lever was off. Is there something I am missing or is this simply get a mallet and wack harder? Throwing the rotors away so not worried about them but seemed it was more than just physically stuck?
    Feb 2010
    Atlantic Beach, Fl
    81,e21 orig ownr&05,e60
    Can you turn the rotors? If yes then parking brake is not the problem. May be corrosion holding the rotor top hat to the hub. A good hit to the top hat of the rotor followed by a lighter hit to the outside perimeter of the rotor should free it up. If it is the e brake, there is a adjuster on the e brake assembly at the bottom accessible through one of the lug bolt holes. Put 2 lug bolts partly in and use a long screwdriver or breaker bar to rotate top hat for alignment. Use a flat tip screwdriver to back off adjuster to free up brake shoes.
    Good luck.
    https://www.pelicanparts.com/techart..._Adjusting.htm
    Aug 2018
    Raleigh, NC
    2008 BMW 535i
    Cannot turn the rotors which is why I kept thinking something weird was going on. Will try to loosen the parking break as you described and see if that works.
    Thanks for the info
    Feb 2010
    Atlantic Beach, Fl
    I added a Pelican parts tutorial link to my earlier post.
    Jul 2017
    Oxford, MS
    2010 BMW 528xi 2001 530i
    I used a 4lb sledge and a wooden block at noon, 3,6, and 9 finally broke loose and I’m in the south with no salts/rust
    2005 RHD TJ Sport
    2010 BMW 528xi
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I used the same method as zipman35, but am in NH where we have corrosion. Have had to use this technique regularly over the years. I do put a very light coat of antiseize on the hub to rotor and rotor to wheel faces and I razorblade and clean/scrape rust off those surfaces when I change rotors and wheels and also off the mating face of the wheel.
  1. 2008 535i rear rotors / brake change - best parts to use?
    By slopson in forum 2004-2010 (E60,E61)
    Last Post: 09-22-2014, 03:17 PM
  2. 2008 535i rear rotors / brake change - best parts to use?
    Last Post: 10-21-2013, 09:40 PM
  3. Stereo issue 2008 535i
    By Spiggz535i in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-19-2008, 12:15 PM
  4. weird brembo rotor issue
    By BJO in forum 1992 - 1999 M3 (E36)
    Last Post: 08-11-2003, 02:04 PM
  5. Rotor issue
    By NightKidz in forum 1992 - 1999 M3 (E36)
    Last Post: 04-25-2003, 01:51 PM
