Results 1 to 10 of 10
Thread: Diagnostic convert problem?
    Sep 2017
    Hungary
    1997 BMW E36 320i
    Hi there!
    I've a little problem with my ADS interface. It's an serial cable as you know, but I don't have an serial adapter on my laptop only on my PC. So... I would like to convert the cable to usb. How can I fix this? Anyone has a diagram to build some circuit for it? Or any ideas how can I convert this ADS interface to usb port?
    Thanks a lot!
    Sep 2017
    Hungary
    1997 BMW E36 320i
    Apr 2014
    UK
    1995 BMW 328
    Read the "Almost free ADS" thread on here.
    Consensus is you can 't.
    In fact you asked the same on your other thread, where I said...……...
    Quote Originally Posted by E36328Coupe View Post
    You'll have to read the whole ADS thread
    Normally no, ADS does not work with USB. There were some posts on there about getting it to work with PCMCIA and funny drivers.
    No warranty of any kind implied or given and no liability for any loss, damage or injury, no matter how incurred accepted.
    Jul 2004
    Houston, TX
    36 Cylinders
    ADS will not work without a true serial port.
    The second question is why do you need ADS? Most modules will work with a K+DCAN and 20-pin adapter. What won't work is KOMBI and ABS/ASC+T if equipped. If plain ABS without traction control, K+DCAN will work.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Apr 2014
    UK
    1995 BMW 328
    ^ Also said in the other thread
    The Netherlands
    DE-spec E36 328i/M3 cab
    Didn't you expience that plain ABS module was a but of a hit 'n miss whether or not you could read them with just K-line?
    ADS is needed for:
    Kombi (aka gauge cluster)
    ASC+T/ABS (and *some* ABS units)
    FFB (remote control module, not applicable to US)
    CVM (vert roof module)
    OBC
    URRS sensor (rollover bars on verts)
    Since I have every possible module on my car, except DDE/EGS, I can say that with just K-line on my 1998 M3 I can get into:
    DME
    GM (ZKE)
    SMG
    ABS
    PDC (parking sensors)
    GR2 (cruise control)
    IHKA
    SRS (airbag)
    EWS
    IG:
    Apr 2014
    UK
    1995 BMW 328
    Quote Originally Posted by MParallel View Post
    Never had any joy on the ABS with a KKL / Vagcom, and my KKL is serial too so no USB in the mix.
    Is your IHKA analogue or digital?
    The Netherlands
    IHKA = digital
    IHKR = analog
    And 1998 will always be digital btw
    Maybe it was another member who needed ADS for older ABS units.
    IG:
    Oct 2003
    New Zealand
    1996 E36 M3 Evo
    Quote Originally Posted by Fireball1991 View Post
    Hi there!
    Thanks a lot!
    As people have said above ADS won't work over USB but you might not need ADS to get what you want.
    Having said this, since you have ADS working already it would pay to see if you can get a docking station from CL or eBay for you laptop - if the docking station (or port replicator/extender) has a real serial port then that'll work. I do this as my laptop also doesn't have a serial port but my docking station does. Slightly less portable but it works and I got my docking station for $10.
    '96 M3, S50B32, 6MT
    + good stuff
    Apr 2014
    UK
    1995 BMW 328
    Quote Originally Posted by M3AN View Post
    In his other thread the OP said...……..
    Thanks but as I know for my laptop I can't buy a dock station:/ Toshiba satellite l755-1nf
    So yet again this thread highlights the pointlessness of starting multiple threads on same thing and repeating answered questions.
  1. Convertible Problems....
    By zimzimma1 in forum 1991 - 1999 (E36)
    Last Post: 09-05-2007, 11:34 AM
  2. Catalytic Converter problem....Help!
    By jgwbmwM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-31-2005, 11:02 AM
  3. catalytic converter problem on l997 328i
    By purple1 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-29-2003, 06:15 PM
  4. 97 convert. problem
    By 97ragtop in forum 1991 - 1999 (E36)
    Last Post: 08-15-2003, 02:14 PM
  5. Exhaust or catalytic converter problem(?)
    By ianv in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-03-2003, 01:59 AM
