My 2001 Z3 has the 3.0L engine and a few "M" logos inside. The guy I bought it from said it was not an M car, but does have the "M Package". I have the original window sticker; there's nothing on it about an "M" anything. Looking for parts, when I specify the 3.0L, I get parts listings for Z3M. Anybody know how to determine which model I have before I order any parts?
Dave
Input the last seven digits of the VIN at realoem.com That should help.
I believe the 01 and 02 Z3 had the S54 engine, which is 3.2 liters. Pop the hood and if you see one throttle body, you do not have the M motor, the S54 which has six throttle bodies.
Moved to Z3 sub-forum.
88M3 AW 43k miles Project FS
There is no such thing as an M Package, buy you may have the sports suspension. Lots of Z3s have the ///M logo in the steering wheel, and may have other odds and ends with the logo on - for instance I have an ///M gearknob, just because I wanted a nice leather one.
You have the M54 engine (not the S54). What parts are you looking for that come up as for the Z3M? Remember, lots of parts are common to all the Z3 models. As mentioned, RealOem will help yuo find the parts specific to your chassis.
You can also just look at the sill plate in the car. If it says "Z3" you have a Z3. If it says "M Roadster" you have a M Roadster. They were sold as separate models and are titled/insured as such.
If it has a 3.0L engine its not an M - its that simple
If it has a 3.2L engine, it IS an M
In the early 2000s, BMW started putting M badges on all of the top level models. My 2001 330ci had “M” wheels, but they were not the ones that came on the M3. It was just a marketing thing. My 2002 Z3 has some M badges, but no “real” M equipment. All of the 3.0i cars in 2002 had M stickers. I believe 2001 was no different.
Some easy ways to tell if a Z3 is an M Roadster:
1. no rear end refresh (i.e. hips) - flat fenders in back.
2. Roadstar wheels (if not replaced)
3. Different side air gills
4. Very different outside and inside mirrors
5. Rear license plate (tag/tab) mounted on the trunk lid, not in the bumper.
6. Dual exhaust - left and right side rear, not tandem on the left only.
7. Lack of a Z3 badge on the trunk lid
8. Chrome work surrounding the shifter boot + M roadster script on the gauges
9. No spare tire bin - battery in the middle of the trunk.
10. Lift the hood and look at the oil filter. Metal cap with a bolt in the center? M...
There’s other stuff... but these are some of the easy ones.
Steve
'02 Z3 3.0i
A thread on that:
https://www.bimmerforums.com/forum/s...st-facelift-Z3
BMW MOA 696, BMW CCA 1405
There is no such thing as an M package.
All Z3s had the sport package, any z3 with the 3 spoke steering wheel will have the M logo on it. Some wheels might have an M on it as well.
But as far as Z3s are concerned they came in two varieties, M roadster/coupe, or Z3 roadster/coupe. There were various options obviously, but thing is, a lot of morons these days throw the word "M package" out there as some kind of sales slogan. I have seen it a bunch when browsing cars. Current generation cars have "M sport" packages, or "M performance" packages, but I think a lot of people like to assume that "M" in the name means more than it actually does.
Also your engine type is M54B30.
The M roadsters and coupes had two variants S52B32 and S54B32. As far as I know, all Z3Ms had always had 3.2 liter motors.
Suspension: Bilstein Sports, GC Coilover conversion, IE Subframe Bushings, IE RTABs, M roadster sways, M roadster front control arms, M roadster Front calipers/hubs.
Engine/Driveline: M54B30 intake Manifold, Dinan CAI, ZHP Cams, Headers, Underdrive pulleys, Conforti Software, 3.46 diff.
• Built S52 w/Dinan ISR-3 kit, NickG Stage 2+ Tune, Dinan Vortech V2 Supercharger, Dinan Air to Air Intercooler, Dinan CAI, Porsche 803 HFM, Buldogge 6" crank pulley, Griptec 2.90" blower pulley, Eurosport UD pulleys, Dinan 3.38 Diff, Dinan front/rear Swaybars, Dinan springs, Koni Yellow Sport Struts, Ground Control end links, South Bend Clutch Stage 3 Organic, AASCO Light Weight Flywheel 18.5#, Zionsville Radiator & Oil Cooler, Riot Racing BBTB, Schrick Intake Manifold, 42# Injectors, Schrick cams 264/256, Forged Wiseco pistons 9.0 comp., Forged Eagle rods, Supertech dual valve springs & valves, VAC crank & bearings, Supersprint mufflers, Euro Z3 midpipe, Raceland euro headers, Walbro 255, Bevauto ignition coils, Vortech Mondo bypass, Bailey Diverter DV30, Ireland Rear Subframe Bushings, Mason Engineering Strut Brace, Mason Engineering Clutch Petal, Apex 18" EC-7 Wheels, Full Custom Sound System, two trunk lids (with & without OE spoiler), Hardtop, Trunk full of AK's...
My 01 with a 2.5 has the M steering wheel, upgraded seats. From what I know about the car, it came from the factory that way.
Tally Ho
http://wcwebs.net/johnson
1988 O'Day 322 sailboat - (unlimited mpg)
2000 BMW Z3 M Roadster (25 mpg - but who cares)
2019 Subaru Outback
(30+ MPG)
Not long after I bought my Coupe I got tripped up by a Koni website that listed a particular front shock for Z3's with the M Sport package. I foolishly that that meant an M Coupe, but found out the hard way that that the springs on an M Coupe/Roadster are smaller in diameter than the M Sport spring for Z3's. Mea Culpa .......
Marty
I have never heard or seen that, but the front swaybar attachment to the suspension goes up to the strut on the M Coupe/Roadster, vs the control arm on the non-M cars. This is to reduce the motion ratio and increase the efficiency (effectiveness) of the swaybar, allowing the bar to be smaller and lighter on the M cars vs the non-M cars.
So, non-M struts will not have a swaybar attachment point on them.
-Anthony Magagnoli
#80 BMW M235i Racing - Pirelli World Challenge TC - 2017 Rookie of the Year
Rooster Hall Racing / FCP Euro
'87 BMW SpecE30 #007 - 2012 NASA SpecE30 NATIONAL CHAMPION
'08 BMW "130i" 6MT, '01 Z3 3.0i Coupe 5MT
'88 Pontiac Fiero GT 5MT (my childhood dream car!)
Send Your Teens to Street Survival
Drive Faster Now
From what I'm able to recall when Z3 3.0 and all other ones first came out (looking at it from the dealer showroom), I'm pretty sure that M-package wasn't offered. Only sports package existed back then, and it was common for BMW to put M badges on certain sport package parts (like rims, steering wheels, and etc). - I don't know if they still carry that approach nowadays.
But from what I have been able to gather past a few years, the Z3 3.0 do seem to share more parts with Z3M's than other Z3 variations though...
2000 Z3 M Titanium Silver / Imola Red+Black Nappa
2011 328i E92 Space Gray Metallic / Leder Dakota+Oyster
Since 1987 12 euros / 2 kdms / 2 jdms
- Zach
What makes an M unique is their engines, differentials, suspensions and interiors that were not shared with any other model (some euro models got seats but rest of interior was still unique to the M). Even if a 3.0 shares more trim clips with an M, that doesnt make it any more "M" than any other non-M Z3
Curious what parts an M shares with 3.0 that it doesnt share with say, a 2.8?
- Zach
There are a couple of minor parts, the rubber bushing is odd to me, they should all ideally be the same, as they are interchangeable to my understanding, but curious as to why it is different. the 2.5, 2.8, 2.5i all have the same part number. 3.0 does not, and it is also like $300 for the bushing
Evidently the 2.5, 3.0, and 3.2 all have different axles and stub axles as well.
In addition to having a different diff bushing, the 2.5 and 3.0 also have different diff covers.
I've got all 3 on a bench and will take some pictures tonight if it's interesting to anyone.
Edit: I take it back - the 2.5 and 3.0 appear to have the same casting for the diff cover, just the bushing is different, which explains the different part number.
A lot of the parts on the M Roadster/Coupe are shared with the E36 M3. However, the stub axles are not shared with any other models and are expensive. I ordered one at the dealer and had to wait 3 months while stock was replenished in Germany and shipped to the states.
I agree. I wonder what lead BMW to make decision on which part is shared between 3.0 and 3.2 (aside from fitment) because I would think 2.8tu should've been included also for something like the stiff OEM bushing for diff. mount (if so, it might have made the part cost considerably less than what it currently is, sigh)...
- Zach
I seem to be creating more confusion, sorry. I meant to say stiff OEM bushing for diff. mount:
- Zach
