Results 1 to 5 of 5
Thread: Where did this bolt come from?
    Jul 2018
    Michigan
    2002 BMW 540i
    Whilst taking the wheels off to get at the brake pads on the rear of my 540i, this bolt fell off and I cant figure out where it is supposed to go. Any help is appreciated.
    bolt.jpg.
    Jun 2016
    North Carolina
    03 525it/5, 1967 GTO
    I’d venture to say that’s not an OE part. It’s a locking castle nut with cotter pin. Commonly used in SAE applications like wishbones and trunions on Brits. BMW uses metric self locking hex nuts. Maybe the PO used one from his spare parts bin?
    Jul 2018
    Michigan
    2002 BMW 540i
    Would make sense that its not OE cause it came off from just me kicking the tire and i couldn't find one like it on the other side.
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Herrrrmmmm... Yeah that looks like it came off the wheel bearing retainer for my old boat trailer. Or the rear axle nut off my mini-bike I had when I was 13.
    Are you sure it wasn't just knocking around on the ground where you were working?
    (PS: also - pro-vocab-tip - that's a nut not a bolt).
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Nut jab this early?
    Tie rod castle nut with cotter key. Check the treads and you will see they are SAE not metric. I vote for on the ground as the cotter key was pulled out from the hole not broken off.
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
  1. Bolts coming out the differential?
    By TofyM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-22-2012, 09:26 PM
  2. Axle bolts coming loose
    By swooper77 in forum 1983 - 1991 (E30)
    Last Post: 11-02-2011, 11:07 PM
  3. Do oil pump bolts come loose on M62TU?
    By JaxMustang50 in forum 1995 - 2001 (E38)
    Last Post: 07-15-2011, 09:07 AM
  4. Rear camber bolt coming loose
    By jrotax101 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-28-2010, 10:07 AM
  5. Lower Strut Mounting Bolt Coming Out
    By KYMark in forum 1991 - 1999 (E36)
    Last Post: 05-31-2009, 10:20 PM
