I’ve been chasing my tail on these misfires. I have also seen my valve cover is leaking.
Can this condition cause misfire on cylinders?
Are bank-2 sparkplug wells clean + dry?
a leaky valve cover can cause misfires.
If I were to do this job, will I only need this kit?
https://www.fcpeuro.com/products/bmw...BoC-hgQAvD_BwE
How about new bolts?
How easy is it to do the oil housing gasket gasket?
the kit will do the job. difficulty level is moderate but takes several hours considering the number of parts to remove and reassemble. must have universal joints, extensions, and deep socket set to do diy job
I prepping the job. So far, 2 hrs.
Finally off. The owner may not be changing his oil regularly
Ok. What the shite are we looking at?
That is hardened oil sludge monsters?
If so, that is beyond epicly scary.
You've gotta interpret that nightmare.
Further, congrats on gittins so far.
Any special tools or surprises besides the volcanic solids?
No special notes to write about.
You just get everything out of the way.
