Results 1 to 9 of 9
Thread: Lost Brake Light and Dash Lights...
    Jul 2010
    MPLS, MN
    1995 BMW 530i/5
    Hey all,
    I haven't signed on in years, as my E34 has been upgraded to my satisfaction and has been trouble free for a long time.
    Last night on the freeway, I lost my dash back-lights and got a "parking light" message. When I got home, the left brake light was out.
    I found an E36 thread about this same issue. Suggestions were a bad bulb, bad fuse and bad wiring. I guess these lights work off the same wiring in an E36.
    While all this stuff is easy to check, I figured this would be a good reason for me to come back on the forum too.
    Here's the car if anyone is curious:
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    slap with your hand slightly on the dash above the cluster and see if the cluster lights come on again.
    Jul 2010
    MPLS, MN
    1995 BMW 530i/5
    Quote Originally Posted by shogun View Post
    That's always what I do first, and I'm about 50/50 with that repair. It failed...
    Jan 2005
    Japan
    so what else did you check?
    Fuses?
    The 4 wire plugs on the rear of the instrument cluster?
    Nov 2011
    Riverside, CA
    01 M5, 93 M5, 94 525iT
    If all those things fail, check the wire loom in the driver side trunk hinge.
    Tommy L.
    oOO \ (IIII) (IIII) / OOo)
    -o- (##########) -o-
    2001 BMW M5 LMB
    LHD Euro
    Bilstein PSS, Black Kidneys, Dinan Rear Anti-sway Bar, Matte Black Style 65, UUC SSK w/DSSR, Alpine iLX-007, Alpine MRV-F 340 Amp, Boston Acoustics Pro components, Alpine MRP-M450 Amp, Infinity Kappa 102.7W Sub x2
    Current Garage:
    1993 BMW M5
    1994 BMW 525i Touring 5spd
    2004 Ford SVT Lightning
    Sep 2008
    NYC<-->LI
    '06 X5/6spd 3.0
    So was the A. parking light back on when you got home? and B. brake light message up on your dash? Sounds like it could be a short or ground issue somewhere.
    I toasted 2 or 3 fuses trying to figure out why #5 / passenger parking light was blowing the instant I flipped the switch. Turned out the socket for the sidemarker light which had been tucked behind euro trim was shattered and shorting in there.
    Mar 2005
    NH
    E34 540i 6sp 1995-03-28
    I can’t remember exactly what I lost I think tail lights on dash lights dome lights were part of it instrument cluster maybe but on the driver side floor near the fender that’s to the left side under the carpet is a large yellow Wiring connector it’s perhaps 4 to 6 in.² that is loaded with wires and is vulnerable to corrosion from moisture my car had holes in the floorboard and eventually those wires corroded and broke and I just had to splice some of those wires back together
    Jul 2010
    MPLS, MN
    1995 BMW 530i/5
    I appreciate the responses and hopefully will have time this weekend to dig into it a bit more. If new bulbs and fuses don't work, I now have more places to inspect.
    Apr 2014
    Northern VA
    e34 m5, touring; e46 (x2
    Quote Originally Posted by bigsixe34 View Post
    Thanks for the suggestions as this may be my problem.... I keep blowing fuse #6 (turn signals and hazard lights) during heavy rains or after car washes. After sitting for a day or two, the fuse stops blowing and all functions return to normal. Couldn't find signs of any leaks re: front turns and rear tails, but it never occurred to me to check for moisture/water in the sockets behind the euro trim. Should be an easy fix if this is the issue.
  1. Brake and ABS dash lights stay on.
    By chazsandiego in forum 1988 - 1994 (E32)
    Last Post: 07-11-2017, 12:13 PM
  2. noob: brake job and dash light is still on?
    By Mr Kelley in forum 1996 - 2003 (E39)
    Last Post: 03-28-2012, 11:40 PM
  3. head lights and dash lights bright than dim
    By sjrider in forum 1991 - 1999 (E36)
    Last Post: 04-20-2011, 07:11 AM
  4. Head Light Switch dash light
    By Im Over It in forum 1991 - 1999 (E36)
    Last Post: 12-29-2007, 12:26 AM
  5. Tail light failure, dash light failure
    By BZBeamr in forum 1991 - 1999 (E36)
    Last Post: 11-30-2004, 11:33 PM
