Results 1 to 4 of 4
Thread: Battery replacement 2008 X3
    Apr 2017
    San Francisco
    2008 X3, 1931 Ford A
    Just noticed my battery getting low, its a 2012 battery.
    Sooooooooo, I wanted to replace it with an H-8 battery from walmart. (the battery for my car)
    Can I just replace it, or do I have to go thru all that registration shit using the BMW logger etc..... to advise the car it has a new battery and avoid overcharging??
    I'd prefer to avoid all that nonsense, dealer or repair shop is absolutely OUT OF THE QUESTION.
    TIA
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to X3 forum
    Mar 2014
    AL
    X5
    If it has larger battery specs, you need to register it.
    Jan 2016
    Ca
    2001 525it
    Regardless of battery type you have to register it and if it had a lead acid in it and you put an agm in you will have to update the battery info before registering it
  1. 2006 x3 wont start after battery replacement
    By kandegirl in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 11-24-2015, 06:59 PM
  2. 2008 e66 battery replacement
    By big7 in forum 2002 - 2008 (E65, E66)
    Last Post: 05-20-2015, 03:06 PM
  3. 2008 M5 Battery Replacement advice needed
    By RalphBMW in forum 2006 - 2010 M5 & M6 (E60, E61, E63, E64)
    Last Post: 05-09-2013, 06:50 PM
  4. Replacing battery on 2008 650i
    By jwsilcott in forum 2004+ (E63, E64, F06, F12, F13)
    Last Post: 12-01-2012, 12:44 PM
  5. 2008 Bmw 550i Key fob battery replacement
    By 1989 e3o in forum 2004-2010 (E60,E61)
    Last Post: 11-22-2012, 11:42 PM
