RM European Auto Parts
Results 1 to 11 of 11
Thread: Brake Brand 2001 z3
    Aug 2018
    Cupertino CA
    2001 Z3 3.0
    Brake Brand 2001 z3
    I just bought my first BMW car (I once owned an R90/6). It's a beautiful 2001 Z3 roadster with the 3.0 engine and a hardtop. 88k miles.The pre-purchase inspection showed the brakes down to 2mm, so that will be my first repair job. I drive fairly conservatively, and will put maybe 6k miles per year on this car. I see rotor & pad sets from $45 per axle. My questions:
    Solid or drilled rotors?
    Ceramic or metallic pads?
    Any brands people have had problems with?
    Recommendations?
    Thanks,
    Dave
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    i've run stock pads/rotors for many years with great results. no real need for drilled/dimpled rotors at all. the stock gear works very well. check the brake hoses and the fluid as well - the fluid is likely due for a flush.
    general advice i give all new bmw owners:
    look into and join the BMW Car Club of America (BMW CCA - www.bmwcca.org/join) and check out your local chapter. chapters often have the best info on qualified shops local to you.
    if you are going to do things DIY - be sure to look into a Bentley service manual.
    purchase quality parts from trusted BMW suppliers including dealers. FCP Euro, RM European, and Pelican Parts are all quality/trusted suppliers.
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    +1 !!!
    Do NOT buy $45 pad rotor sets -- they will be absolute GARBAGE ! Buy your brakes from one of the places shadowpuck mentioned above.
    I recommend against drilled rotors. They crack and craze, and are very noisy, for no benefit whatsoever.
    You didn't say front or rear, so I'll price fronts for you. This is what I'd recommend:
    PADS: https://www.fcpeuro.com/products/bmw...t-front-d1131a
    Rotors:
    https://www.fcpeuro.com/products/clo...ft-34112227171
    https://www.fcpeuro.com/products/bmw...nn-34112227172
    (Um, you can buy Meyles at ~$15 cheaper; they are also OEM, but the Zimmermans are made in Germany, the Meyles in China.)
    You will also need a sensor:
    https://www.fcpeuro.com/products/bmw...ro-34352227385 (I do not know why the printing for the link says "URO", (bad), when the link takes you to a BOWA part (good).
    Chris Powell
    BMWCCA 274412
    Aug 2018
    Cupertino CA
    2001 Z3 3.0
    Thanks so much for the info. I'll ordrr frim them.
    Feb 2008
    Mt. Pleasant, SC, USA
    1997 E36 M3/4/5
    Given what you do, stock is fine. If you drove a lot and had preferences for clean or higher temp pads for hard driving (ie drivers Ed events), then there is a range of decent aftermarket alternatives. I'd keep it simple for your car.
    Marc Plante
    E36 M3/4/5 193k
    Konis+ Dinan Springs, Understeer SS, Shepott European steering Wheel, ZKW Ellipsoids, ECIS Intake+ ATE Foam filter, Stromung Exhaust, Recaro SRDs. JVC Arsenal Head Unit. Alpine MRV-F300 Amp, ADS 535i components, JL Audio Stealthbox Subs
    My Track Rig:
    i7700 / 2080 PC with Assetto Corsa and Content Manager, Samsung Odyssey+ VR goggles
    Fanatec CSP wheel and pedals, SSH Shifter, recaro seat. Home built cockpit
    Mt Pleasant, SC, USA
    NW suburban Chicago
    hiss by my window
    No reason for slotted or drilled rotors. Boy racer hoo-ha. Don't get sucked into high performance stuff unless you really intend to be pushing hard.
    MY criteria would be based on how hard your wheels are to clean. The OE pads have great pedal feel, work well cold, aren't too hard on the rotors and can stop much harder than most people would be comfortable with. BUT they are dusty.
    Ceramics are rougher on the rotors but make a lot less mess of the wheels.
    So, nice smooth 5 spoke wheels and I'll buy OE pads, complicated ones with lots of nooks and crannys and I'll buy ceramics.
    Cheap stuff is cheap stuff, so 'nuff said there.
    Feb 2008
    1997 E36 M3/4/5
    Also your local BMWCCA will have tech sessions to teach you how to do a lot of basic repairs.
    Marc Plante
    E36 M3/4/5 193k
    My Track Rig:
    Aug 2013
    1999 BMW M3 Coupe
    For the street I strongly encourage you to just buy quality blank (not slotted/drilled) OEM rotors from a good brand like Centric/Meyle/Zimmerman/Brembo/Stoptech/etc... For pads, the BMW OEM pads are great on the street; they bite hard when cold and last a very long time. If you go aftermarket, be aware that if you get any of the "higher performance" street pads that you'll likely be losing quite a bit of cold bite over OEM. This means that you'll have to press the pedal harder to brake the same amount, especially when they aren't warmed up or are wet. The benefit of such pads is that they can tolerate more heat without fading in track situations, but they can be occasionally frustrating on the street if you aren't used to them. I won't begin to give you aftermarket street pad suggestions since there are literally dozens out there. Popular brands are Hawk, PFC, Pagid, Cool Carbon, EBC, and many others.
    Also, make sure and bleed the brakes if you're doing pads and rotors. It's also a good time to do brake lines if desired, and also to rebuild calipers if necessary.
    Nov 2019
    Charleston, SC
    BMW Z3
    Use organic pads this is what BMW's come with from the factory. They won't wear out your rotors like metallic or ceramic, and they stop on a dime. Only draw back is the brake dust. Slotted or drilled rotors are a gimmick. The more surface material the better the braking. And organic pads don't create heat. Hope this helps....
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    If you’re dust-phobic, buy a bottle of RejeX, clean the wheels and put a couple coats of the stuff on the wheels. Brake dust basically rinses off.
    Jan 2016
    Ca
    2001 525it
    I run textar pads and rotors
  1. Z3 E36/7 2001 Z3 M Roadster Brake Calipers, Brackets, Hardware...
    By Ben Carufel in forum Z3,Z4,Z8 Classifieds
    Last Post: 06-23-2015, 11:52 AM
  2. Replies: 0
    Last Post: 09-09-2009, 09:35 AM
  3. 2001 Z3 3.0 Roadste.r / Emergency brake
    By ptown500 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-30-2006, 11:40 AM
  4. Springing noise with brake pedal, 2001 Z3 3.0L
    By Theanimedude in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-22-2006, 01:13 PM
  5. Will 15" rims fit over the rear brakes of a 2001 Z3 3.0?
    By SilverStreak in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 01-15-2003, 12:57 PM
