Results 1 to 6 of 6
Thread: 2004 E85, 3.0i Motor Mount Question
    Sep 2014
    Arkansas
    2004 BMW Z4 3.0i
    About a month ago, I noticed popping coming from under the vehicle as if the protective plastics were buckling from the chassis twisting. So I removed all front cap and all undercarriage protective plastics and still popping. I narrowed the search down towards the middle of the engine, after looking at the drivers side motor mount there appears to be fluid around the in a small narrow cavity around the mount itself.
    Question: Is it supposed to leak fluid? I've never known motor mounts to contain fluid - I'm thinking this is bad!
    My vehicle has 105K miles, so I'm guessing changing them about will rid me of the popping?
    Thanks!
    Feb 2013
    Canada
    2004 Z4R 06&12 Cooper S
    Most stock BMW motor mounts are liquid filled.
    I would replace with a good quality aftermarket rubber piece.
    Also if your suspension has not been refreshed the FCAB's could be knocking.
    At 105k it is time for refreshing lots of things if not already attended to.
    04R 3l 6 sp VF SC, custom ducting, alphaN, 2.62 pulley, multiport WMI,Severn Tuning(Pokeybritches), Tial BPV,Ceramic header, magnaflow section 1, SS race muffler/y-pipe, megan mounts,42 design catch can, CDV delete ,custom strut bar,3.91 LSD, H&R bars, Hotchkis links.Eibach Pro Kit,Koni Yellows.Megan camber arms. Carbon interior,SSK,UUC lines.CF aero. Poly bushings.
    Ensure the leak is not something from up above first...
    Mar 2018
    columbia, sc
    2004 BMW Z4
    I have been a first time BMW owner for 1 year. I own a 2004 BMW Z4, 3.0i, auto, Black Sapphire exterior, Oregon Beige interior, Now has 51,200 miles, Sport package, Premium Package, Convenience Package. Stock car.
    Jan 2016
    Ca
    2001 525it
    There is a popping noise that came happen it is at the middle if the fire wall where the over lapping strut bars meet, it sounds like it is at the base of the windshield the nut needs to be retorqued the nut is never loose but loosen it and re tighten it and if that is the noise it will go away, this also works on the 6 series
    Mar 2011
    Southwest, Ohio
    2007 Z4 3.0Si
    Quote Originally Posted by jclausen View Post
    What they said.
    My popping noise was coming from right at the base of the windshield and sure enough, it was loose and I found out that the factory specs on the cross brace nuts are 41nm(~30ft/lbs) on the nut and sure enough, they were much looser than that.
    the two nuts right below the wiper blade/cowl cover.
    Yes, I know. Not my car but its dark and cold out there and too lazy to go snap a pic of mine...
  1. Competition Motor Mount Question
    By Green95Bimmer in forum 1991 - 1999 (E36)
    Last Post: 03-08-2008, 10:19 PM
  2. Motor Mount Question...
    By Hawkster in forum 1992 - 1999 M3 (E36)
    Last Post: 05-16-2006, 08:22 AM
  3. Motor Mount Questions
    By JordanMD88 in forum Forced Induction
    Last Post: 04-28-2006, 01:45 PM
  4. solid motor mount question
    By thewal2 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-26-2006, 10:52 PM
  5. Motor mount question
    By M-tinker in forum 1992 - 1999 M3 (E36)
    Last Post: 04-28-2003, 03:57 AM
