Originally Posted by
ed323i
If the torque curve is more or less comparable (so you can't compare turbo or supercharged engines to natural aspirated engines), the weight/hp ratio, or with the M52, because of it's down-tuned engines HP-wise, better to use weight/torque ratio.
So, your 320i weighs 1280 kg and has 150HP (190 Nm), so each HP has to drag along 8.5 kg OR each Nm has to drag along 6.7 kg
A 323i weighs 1280kg and has 170HP (245 Nm), so each HP has to drag along 7.5 kg OR each Nm has to drag along 5.2 kg
A 328i weighs 1280kg and has 193HP (280 Nm) , so each HP has to drag along 6.6 kg OR each Nm has to drag along 4.6 kg
The (European) 323i and 328i probably weigh a few kilos more due to bigger brakes, bigger differential, etc. But it's in the ball park.
US models are probably more luxurious and way a bit more due to rear electric windows, exhaust air injection pump and probably some other stuff. Automatic gearbox also adds quite some weight (and worsens accelerations).
So, it's very simple, if you could get the weight down so much that you'd get to the 5.2kg per Nm (same as the 323i), you'd be faster than a stock 323i, because your car has a shorter ratio differential.
At high speeds above say 150 km/h (say 100 mph) the weight doesn't matter that much anymore because the air drag is what has the biggest influence on the acceleration of the car. So, you need raw HPs and the 323i and 328i will then outrun the 150HP 320i, even if you have the same weight/hp ratio.
But especially at 0-100 or even 0-120 km/h sprints, the weight/nm or weight/hp ratio determines a lot (unless one of the cars has a much better torque curve, and to be honest, the M52B25 and B28 have a somewhat better torque curve).
To put it differently, to get as fast as the 323i you'd need to drop weight to 992 kg.
To get as fast as the 328i you'd need to drop weight to 868 kg.
Both targets are virtually impossible, because you're talking about E30 4 cylinder weights (E30 316).
Because of the shorter ratio differential, I think you'll get in the ball park of the 323i if you could a bit past halfway the weight target, so, say 1100 or 1150 kg.
But, then again, that's still a very major weight drop.. Virtually impossible without very drastic measures.
Best to just give it a try. Rear seats, spare tire, unused floor mats, unnecessary tools in the trunk, etc. It ain't that much, but I'm sure you'll feel a difference. Won't be shocking though..
P.S. Carbon fiber hoods and carbon trunk lids would also help, but those are way too expensive ;-) .
