Results 1 to 14 of 14
Thread: Well I just messed up my headlamps..... GRRRRR
    Osnabrock, ND
    2004 325xi,2004 545i SMG
    So my xenon bulb exploded on pass side, and I purchased a new set of bulbs. well removed headlamps from vehicle and inspected and replaced bulbs. found drivers side light had corrosion on connector for adaptive headlamp module on bottom of lamp (what a hell of an idea BMW). so Stupid me grabbed some electrical contact cleaner and my cleaning kit and cleaned the connections up. ok simple enough. Wasnt thinking and when I turned the lamp back over the electical contact cleaner ran on the inside of the lens. GRRRRRRR now its stained on the inside.
    put a little bit of water in through the breather vents on back and quickly tried to rinse off the lenze and then removed the moisture but the lens is stained and F'ed....
    I have been reading a few posts on E60 forums and they are all just a bunch of people arguing about how to remove the lens to install some angel eyes. there are some you tube vids but they are also very unclear on what needs to happen to seperate the lens from housing.
    Anyone do this?
    Level 1 Certified BMW tech.
    Osnabrock, ND
    no one has taken the headlamps apart and not destroyed them?
    Jul 2017
    Oxford, MS
    2010 BMW 528xi 2001 530i
    I was under the impression that the xenon was a sealed unit
    2005 RHD TJ Sport
    2010 BMW 528xi
    Osnabrock, ND
    yes, they are sealed and BMW does not sell replacement lens for them but many other companies do, I am really confused as to how to open them and change the lens without completely destroying the lamp.
    BMWJake sells a good set and the glue and what not but if its something I dont wana take on then I wont.
    Jul 2017
    Oxford, MS
    Ok so what year/series are you driving?
    2005 RHD TJ Sport
    2010 BMW 528xi
    Osnabrock, ND
    Quote Originally Posted by zipman35 View Post
    2005 RHD TJ Sport
    2010 BMW 528xi
    2004 545i E60
    Jul 2017
    Oxford, MS
    Well I looked over night and from what I can tell it would be better just to replace the whole assembly
    True you may can find the lens for about $150. Pry it off with heat, screw drivers, and flat blades. Clean up the edges and use the OCI butyl rubber glue to put the new lens in place
    That just seems like a whole lot of time and trouble for something you might could find for not much more money
    2005 RHD TJ Sport
    2010 BMW 528xi
    Osnabrock, ND
    2005 RHD TJ Sport
    2010 BMW 528xi
    have you looked at what a new headlamp assembly costs? 1500 or so from BMW, 750 or so from ebay. ECS has for 700ish.
    even salvage yards around here want 500 plus for a assembly.
    Jul 2017
    Oxford, MS
    I buy most of my parts from FCP. They run about $350 ish there free shipping
    I’m just thinking about labor and something that is not a real common DIY you come across.
    2005 RHD TJ Sport
    2010 BMW 528xi
    Osnabrock, ND
    2005 RHD TJ Sport
    2010 BMW 528xi
    Are you sucking someones you know what to get that deal? I just checked FCP euro site and they are 726 left and 726 right.
    https://www.fcpeuro.com/products/bmw...la-63127166119
    Feb 2010
    Atlantic Beach, Fl
    81,e21 orig ownr&05,e60
    Here's a link to a guy in France that customised his light modules, to enclude new lenses. https://www.bimmerfest.com/forums/sh....php?t=1288704
    Google can be your friend here. There are at least 5-6 threads over the past 6-8 years on guys diying headlight repairs on this forum and 2 others.
    Good luck.
    Jul 2017
    Oxford, MS
    When I looked it up the day I posted there was a cart add discount dropping it $40
    2005 RHD TJ Sport
    2010 BMW 528xi
    Jul 2017
    Oxford, MS
    Oh hell wrong light. That’s not the base model . Yea mine are like $850 too
    I just did my own repair for a cloudy lense that came out great but the inside...
    That link to BF looks like a winner to me
    2005 RHD TJ Sport
    2010 BMW 528xi
    Osnabrock, ND
    2005 RHD TJ Sport
    2010 BMW 528xi
    yup wrong headlamp!
  1. A woman I work with just messed up w/ oil..how bad?
    By mDeb in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-12-2002, 04:48 PM
  2. Did I just mess up my door panels?
    By Chuck in forum 1992 - 1999 M3 (E36)
    Last Post: 10-02-2001, 01:50 PM
