Results 1 to 2 of 2
    Aug 2018
    Panama
    2008 e70 30d
    Low/foamy coolant on 2008 e70 30d
    Hello guys, I'm new over here but not new to BMWs. So I started receiving low coolant message on my 08 X5 and have been topping it off with coolant and water. First time this happened I used good quality coolant to top it off but when I received the low coolant light again in two days I decided to top it off with cheap coolant/regular tap water until I fixed the issue.
    Now while topping off the expansion tank I noticed the coolant was slightly foamy. The foam was white. At first I suspected a blown head gasket but the oil is fine and I see no white smoke coming off the exhaust.
    There is no noticeable puddle of water/coolant anywhere I park but the leak is considerable since I have to put about 3 quarts of water every two days. The car runs fine and I haven't had the overheating light ever.
    Aug 2018
    Panama
    2008 e70 30d
    turns out to be the hose that goes from the water pump to the radiator that's leaky.
  1. Coolant issue (low/foamy)
    By tsk in forum 1999 - 2006 (E46)
    Last Post: 08-15-2010, 03:26 AM
  2. Coolant light on but not low on coolant
    By byrd in forum 1999 - 2006 (E46)
    Last Post: 01-10-2010, 12:01 PM
  3. low engine coolant?
    By obeythelaw in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 11-08-2009, 09:54 AM
  4. Cold, low pressure coolant leak
    By mreloc in forum 1983 - 1991 (E30)
    Last Post: 08-25-2007, 07:55 PM
  5. Low coolant light on but not low on coolant?
    By HeLLroT325iS in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-02-2005, 01:45 PM
