Results 1 to 7 of 7
Thread: e39 remote question...no red LED on remote
    Nov 2007
    Florida
    1998 528i manual
    Picked up an 11/97 528i a few months ago with a single key and the remote not working on any buttons. It's the older square style. With a good battery, but no red LED lighting up on the remote, can I assume the remote is broken and needs to be replaced? Fuses all test good and car starts and runs fine.
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Check to make sure that the battery holder is still attached to the PCB as solder cracks often.
    Sep 2008
    West London/Heathrow - UK
    03 530dT - Ex Police Car
    Hi,
    Also check/search the E39 section and then post if needed. There's some online sellers for refurbished fobs and/or spare parts for them on ebay etc which are relatively cheap so you could try those as well.
    Cheers, Dennis!
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to E39 forum
    San Jose, CA
    1997 BMW 540i 6 speed
    Your model has a replaceable battery inside the key. Have you verified that it's good? S/b 3V.
    Some key makers have an instrument that can detect the presence of the transmitter signal.
    The Netherlands
    DE-spec E36 328i/M3 cab
    You can check its status by pressing the trunk release and lock button simultaneously. If OK the led will light up for a second.
    IG:
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    Quote Originally Posted by Maverick740 View Post
    Does this mean you have the older (old style) remote that DOES NOT have the red LED (it uses TWO 1220 batteries)...or the old style remote with the red status LED uses a single 2016CR battery? I can't tell if you're saying the red LED is there but isn't lighting up when you press the buttons on the remote...or if you don't have a red LED on the remote at all. :
    It's also not clear if you've tried to reinitialize the key. You wrote "remote not working on any buttons"...is the IC board inside the remote damaged & causing none of the button actions to perform...or is the remote just not initialized to the car?
    Below are the instructions on how to reinitialize the remote key. You must follow the instructions exactly as written or initialization will fail. Also take note of the tips which can also cause programming failure:
    TIPS:
    • KL R = ignition position 1 (not position 2 or engine running)
    • All doors MUST be CLOSED
    • All doors MUST be UNLOCKED
  1. E39 On Auction BMW E39 528i 540i clear/red Hella Celis LED upgrade kit
    By mrkyle229 in forum Exterior Lighting & Body Parts
    Last Post: 06-30-2010, 09:51 AM
  2. Question on e46 m3 key remotes
    By Revo86 in forum 1999 - 2006 (E46)
    Last Post: 10-09-2005, 03:44 PM
  3. Installing amp remote questions...?
    By bwo1525 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 09-14-2005, 10:49 PM
  4. Alpine keyless remote question
    By dvx_movies in forum 1991 - 1999 (E36)
    Last Post: 04-23-2005, 02:20 PM
  5. Keyless Entry Remote Question
    By toddman35 in forum 1991 - 1999 (E36)
    Last Post: 04-09-2003, 12:28 AM
