Results 1 to 8 of 8
Thread: 2001 740il no crank no start. Purchased at auction this way.
    Aug 2018
    Olympia, WA
    2001 BMW 740il
    Hello I am a brand new member and just picked up a 2001 740il with 125k from a local auction. It does not crank or start. Please help me figure out whats wrong.
    Here is what i've found so far.
    No power to starter relay on pin 86 or 30
    Car also has no P light on dash gear indicator, i purchased a used neutral safety switch from a 97 740il with no effect.
    It seems that the ews is not working/ allowing power to be applied to starter relay, but would the NSS cause this? Basically which should i figure out first?
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Welcome to the forum. If the DME doesn't see it's in P or N, it's not going to do anything. Have you checked the ebox to make sure the modules are there and plugged in? Everything look good under the plate at the gear shift?
    Selector position lights don't care anything about the EWS. It should come on even without the key in the ignition.
    Aug 2018
    Olympia, WA
    2001 BMW 740il
    Quote Originally Posted by Mayorchuck View Post
    Looks like i need a wiring diagram for the Neutral safety switch then. Power to the starter comes from EWS, i need to figure out how the DME ties into the no crank condition.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Aug 2018
    Olympia, WA
    2001 BMW 740il
    i tested power and grounds to the DME and EGS, they are good. I scanned the car with a friends laptop using carsoft software i believe and most modules wouldn't respond. Heres a pic of what showed up.
    Aug 2018
    Olympia, WA
    2001 BMW 740il
    well guess im not allowed to post pictures. Anyway i believe that the dme and egs are done for since they do not respond but have good power and ground supply. Does the egs require coding if replaced with used?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    As long as you get an EGS from the same year and model no programming is needed
    My BMW Repair YouTube Channel
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Quote Originally Posted by ctiedje03 View Post
    It's just your low post count. New members need approval to post photos or links. This is a spam preventative. If you use a photo host site and copy the IMG into the post, it will send a request for approval. One of us usually approve it within a few hours.
  1. E38 2001 740iL Smokes on start up
    By 1GR8RIDE in forum 1995 - 2001 (E38)
    Last Post: 01-21-2016, 12:49 PM
  2. 2001 745il no cranking/no start
    By mahiluck in forum 1995 - 2001 (E38)
    Last Post: 06-18-2011, 02:26 AM
  3. Purchase of a 2001 740il
    By kuladog in forum 1995 - 2001 (E38)
    Last Post: 02-04-2011, 05:11 PM
  4. 2001 740il HARD START PROBLEM
    By Rashad2gs in forum 1995 - 2001 (E38)
    Last Post: 08-14-2009, 08:32 PM
  5. 2001 740iL will not start
    By Beldark in forum 1995 - 2001 (E38)
    Last Post: 11-12-2008, 02:06 PM
