Results 1 to 13 of 13
Thread: Cosmos Black E36 M3 Track Car Part Out
    CT
    M3
    PParting out my e36 m3 track car, see below for what is still available and message me with what you are interested in.
    Local pickup preferred and shipping available too as long as you're willing to pay for it.
    Carbon rear wing w gurney flap (NOT a ltw or $1500+ bimmerworld wing but it does make a noticeable difference on the track)
    Passenger door / window seal in good shape
    Door strikers
    Passenger window, passenger coupe quarter windows & rear glass
    Passenger window / roof trim piece (no rust)
    Trunk trim / filler piece in cosmos w reverse lights
    Trunk lock tumbler w keys, latch mechanism etc
    Trunk & hood hinges w lift
    3rd brake light
    Wiper motor
    Complete fuel tank, pump, level sensor, filler neck etc
    18lb Deka EXT18L battery (vs 50lbs for stock) w top post mounts, quick disconnect, & custom track safety inspection approved mount
    Odyssey PC925 lightweight battery ~25 pounds
    New stoptech ST40 e36 rear caliper brackets
    Abs pump, & abs computer / ecu
    Rust free brake lines
    2x diffs online 4 bolt race differentials 3.15 & 3.46 for long vs short tracks. 3 clutch, 40% lockup, 30/90 ramps rem polished gears & bearings etc
    6 bolt driveshaft
    Stock m3 rear subframe w upper & lower control arms
    M3 rear subframe w bimmerworld aluminum bushings
    Upper control arms w ground control spherical bearings
    Bimmerworld lower control arms
    Trailing arms w turner spherical RTABs
    ZF Transmission crossmember
    S52 beauty / ignition coil cover
    Tested good MAF
    Stock throttle body w tested good TPS
    Tested good 02 sensors
    Brake & clutch pedals w pedal sensors
    Slave cylinder to clutch master hard lines
    Secondary air pump
    EGR valve
    Stock coupe tail lights
    Turner delrin fcabs in lollipops
    Steering column w keys + lower shaft w ujoint and rubber flex piece
    Sparco quick release wheel hub
    Black dash & black shifter surround w carbon insert
    clockspring for steering wheel
    Have some E46 & E46 M3 parts too
    E46 non M
    330 / 328 shift selector rod
    Front 1/2 driveshaft for zf 5 speed manual swap
    Steering column
    E46 M3
    Navigation screen / unit
    Radio receiver
    Complete HK sound system speakers amp etc
    Ibus
    Cd changer
    Interior abc pillar trim, lights, and accessories
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    PMed regarding the spoiler and carpet.
    Jul 2018
    Rowland heights, CA, U.S.
    1997 BMW M3 COUPE
    how much for the wing with gurney flap?
    CT
    M3
    Quote Originally Posted by Dannnzz View Post
    Hi Dan make me an offer via pm, whatever you think is fair.
    Aug 2018
    Florida
    2011 BMW 328i
    VRT, How much for your e46 navigation set up?
    TX
    97 M3/4/5, MCS
    what about:
    Driver side window gasket
    porkchops and under panel
    gear selector insulation
    Shift boot with frame.
    NY
    skateboard
    Location?
    ― George Orwell
    Feb 2016
    Westchester NY
    95 M3, 09 FX50, 17 JK
    May be interested in quite a few parts, just purchased my e36 m3... will PM
    09 FX50 // 17 Wrangler JK //
    in search of an e36 m3
    CT
    M3
    listing updated with what is still available
    Nov 2012
    Long Island
    1995 M3, 2011 WRX
    is the pc925 new?
    CT
    M3
    PC925 is in tested good used condition
    Oct 2014
    Memphis, TN
    95 M3, 12 335i coupe
    Interested in BimmerWorld control arms. PM sent
    ct
    1997 M3/4/5
    Sent multiple messages with no response.. Please holler at me VRT- I'm located in CT
  1. E36 M3 track car parts (cams, shifter, jaffster knob, etc.)
    By gbreeE90 in forum Race Cars & Track Parts
    Last Post: 12-26-2013, 05:21 PM
  2. E36 Cosmos Black e36 M3 Exterior Parts
    By 1000hp in forum Exterior Lighting & Body Parts
    Last Post: 08-26-2013, 08:38 AM
  3. E36 E36 M3 Track Car Part out
    By bmw3er in forum Race Cars & Track Parts
    Last Post: 01-31-2013, 09:54 PM
  4. E36 Parting A Cosmos Black e36 M3 Coupe Auto Transmission
    By klodkrawler05 in forum Whole Parts Cars
    Last Post: 11-19-2012, 06:31 AM
  5. E36 M3 track car for sale, or will part out
    By NfamusRcR in forum BMW Cars For Sale / Wanted
    Last Post: 10-26-2004, 10:53 PM
