Parting out my e36 m3 track car, see below for what is still available and message me with what you are interested in.
Local pickup preferred and shipping available too as long as you're willing to pay for it.
Carbon rear wing w gurney flap (NOT a ltw or $1500+ bimmerworld wing but it does make a noticeable difference on the track)
Passenger door / window seal in good shape
Door strikers
Passenger window, passenger coupe quarter windows & rear glass
Passenger window / roof trim piece (no rust)
Trunk trim / filler piece in cosmos w reverse lights
Trunk lock tumbler w keys, latch mechanism etc
Trunk & hood hinges w lift
3rd brake light
Wiper motor
Complete fuel tank, pump, level sensor, filler neck etc
18lb Deka EXT18L battery (vs 50lbs for stock) w top post mounts, quick disconnect, & custom track safety inspection approved mount
Odyssey PC925 lightweight battery ~25 pounds
New stoptech ST40 e36 rear caliper brackets
Abs pump, & abs computer / ecu
Rust free brake lines
2x diffs online 4 bolt race differentials 3.15 & 3.46 for long vs short tracks. 3 clutch, 40% lockup, 30/90 ramps rem polished gears & bearings etc
6 bolt driveshaft
Stock m3 rear subframe w upper & lower control arms
M3 rear subframe w bimmerworld aluminum bushings
Upper control arms w ground control spherical bearings
Bimmerworld lower control arms
Trailing arms w turner spherical RTABs
ZF Transmission crossmember
S52 beauty / ignition coil cover
Tested good MAF
Stock throttle body w tested good TPS
Tested good 02 sensors
Brake & clutch pedals w pedal sensors
Slave cylinder to clutch master hard lines
Secondary air pump
EGR valve
Stock coupe tail lights
Turner delrin fcabs in lollipops
Steering column w keys + lower shaft w ujoint and rubber flex piece
Sparco quick release wheel hub
Black dash & black shifter surround w carbon insert
clockspring for steering wheel
Have some E46 & E46 M3 parts too
E46 non M
330 / 328 shift selector rod
Front 1/2 driveshaft for zf 5 speed manual swap
Steering column
E46 M3
Navigation screen / unit
Radio receiver
Complete HK sound system speakers amp etc
Ibus
Cd changer
Interior abc pillar trim, lights, and accessories
How much for the momo?
listing updated with what is available.
Fresco, I paid 230 shipped and it is in very good condition. Make me an offer via pm whatever you think is fair.
What's your location?
PM pics of the wing.
Current
-1997 BMW M3 4Door Artic Silver w/ Black Interior Daily
Past
-2001 BMW 325i
-1999 BMW M3 Vert White
-1981 VW Rabbit Pickup (Caddy) 2.0 ABA
"I don't care if the door gaps are straight. When the driver steps on the gas, I want him to shit his pants." - Enzo Ferrari
Received, as expected, thanks man
any pictures of the body ?
I'm in CT. have an Nose panel?
Looking for this part #41148122544 Pm me a price.
Hi guys, the nose panel and passenger side frame rail were damaged in the crash.
If anyone is looking for body parts the drivers side frame rail, abc pillars, rockers etc are all available and we will be cutting up the car soon.
Is the driveshaft available?
How much for the clock spring please?
PM sent.
Reached out several times about parts. Please get back to me.
