Results 1 to 15 of 15
Thread: Cosmos Black E36 M3 Track Car Part Out
    CT
    M3
    Parting out my e36 m3 track car, see below for what is still available and message me with what you are interested in.
    Local pickup preferred and shipping available too as long as you're willing to pay for it.
    Carbon rear wing w gurney flap (NOT a ltw or $1500+ bimmerworld wing but it does make a noticeable difference on the track)
    Passenger door / window seal in good shape
    Door strikers
    Passenger window, passenger coupe quarter windows & rear glass
    Passenger window / roof trim piece (no rust)
    Trunk trim / filler piece in cosmos w reverse lights
    Trunk lock tumbler w keys, latch mechanism etc
    Trunk & hood hinges w lift
    3rd brake light
    Wiper motor
    Complete fuel tank, pump, level sensor, filler neck etc
    18lb Deka EXT18L battery (vs 50lbs for stock) w top post mounts, quick disconnect, & custom track safety inspection approved mount
    Odyssey PC925 lightweight battery ~25 pounds
    New stoptech ST40 e36 rear caliper brackets
    Abs pump, & abs computer / ecu
    Rust free brake lines
    2x diffs online 4 bolt race differentials 3.15 & 3.46 for long vs short tracks. 3 clutch, 40% lockup, 30/90 ramps rem polished gears & bearings etc
    6 bolt driveshaft
    Stock m3 rear subframe w upper & lower control arms
    M3 rear subframe w bimmerworld aluminum bushings
    Upper control arms w ground control spherical bearings
    Bimmerworld lower control arms
    Trailing arms w turner spherical RTABs
    ZF Transmission crossmember
    S52 beauty / ignition coil cover
    Tested good MAF
    Stock throttle body w tested good TPS
    Tested good 02 sensors
    Brake & clutch pedals w pedal sensors
    Slave cylinder to clutch master hard lines
    Secondary air pump
    EGR valve
    Stock coupe tail lights
    Turner delrin fcabs in lollipops
    Steering column w keys + lower shaft w ujoint and rubber flex piece
    Sparco quick release wheel hub
    Black dash & black shifter surround w carbon insert
    clockspring for steering wheel
    Have some E46 & E46 M3 parts too
    E46 non M
    330 / 328 shift selector rod
    Front 1/2 driveshaft for zf 5 speed manual swap
    Steering column
    E46 M3
    Navigation screen / unit
    Radio receiver
    Complete HK sound system speakers amp etc
    Ibus
    Cd changer
    Interior abc pillar trim, lights, and accessories
    Mar 2018
    Olympia WA
    1995 530i E34 M62 Swap
    How much for the momo?
    CT
    M3
    listing updated with what is available.
    Fresco, I paid 230 shipped and it is in very good condition. Make me an offer via pm whatever you think is fair.
    Nov 2009
    Wall, NJ
    e36 M3/4/5
    What's your location?
    Oct 2015
    Alabama
    97 BMW M3 Sedan
    PM pics of the wing.
    Current
    -1997 BMW M3 4Door Artic Silver w/ Black Interior Daily
    Past
    -2001 BMW 325i
    -1999 BMW M3 Vert White
    -1981 VW Rabbit Pickup (Caddy) 2.0 ABA
    "I don't care if the door gaps are straight. When the driver steps on the gas, I want him to shit his pants." - Enzo Ferrari
    CT
    M3
    Quote Originally Posted by stix217 View Post
    Canton, CT
    Mar 2018
    Olympia WA
    Received, as expected, thanks man
    Oct 2018
    Illinois
    1995 BMW M3
    any pictures of the body ?
    ct
    1997 M3/4/5
    I'm in CT. have an Nose panel?
    NY
    skateboard
    Looking for this part #41148122544 Pm me a price.
    CT
    M3
    Hi guys, the nose panel and passenger side frame rail were damaged in the crash.
    If anyone is looking for body parts the drivers side frame rail, abc pillars, rockers etc are all available and we will be cutting up the car soon.
    May 2017
    Watertown, SD
    1999 328is
    Is the driveshaft available?
    Nov 2009
    Wall, NJ
    e36 M3/4/5
    How much for the clock spring please?
    Aug 2015
    NYC
    a bunch of broken ones
    PM sent.
    ct
    1997 M3/4/5
    Reached out several times about parts. Please get back to me.
  1. E36 M3 track car parts (cams, shifter, jaffster knob, etc.)
    By gbreeE90 in forum Race Cars & Track Parts
    Last Post: 12-26-2013, 05:21 PM
  2. E36 Cosmos Black e36 M3 Exterior Parts
    By 1000hp in forum Exterior Lighting & Body Parts
    Last Post: 08-26-2013, 08:38 AM
  3. E36 E36 M3 Track Car Part out
    By bmw3er in forum Race Cars & Track Parts
    Last Post: 01-31-2013, 09:54 PM
  4. E36 Parting A Cosmos Black e36 M3 Coupe Auto Transmission
    By klodkrawler05 in forum Whole Parts Cars
    Last Post: 11-19-2012, 06:31 AM
  5. E36 M3 track car for sale, or will part out
    By NfamusRcR in forum BMW Cars For Sale / Wanted
    Last Post: 10-26-2004, 10:53 PM
