RM European Auto Parts
Results 1 to 8 of 8
Thread: Gas needle acting weird
    Jul 2013
    Casablanca, Morocco
    2001 e46 323i
    Here we go again. To each week its issue, at least my weekends are not boring lol.
    So my gas gauge started acting weird last weekend, showing either what I know to be the accurate level of fuel, or about a quarter of a tank higher. Today I pulled up and verified both gauges under the rear seat and they seemed fine since when I moved each one of them respectively to full/empty tank positions, the needle on the dashboard moved accordingly.
    Put everything back in place, needle back where it should be, test drove the car a few miles, turned it off and on several times, all was well.
    I thought maybe the gauge had gotten stuck at some point for some reason and was happy enough for the "easy fix".
    Now after taking the car for a drive it started acting crazy again. About a quarter tank more that should be indicated, and the needle slowly goes back where it should be. Same pattern as before: higher than normal, slowly and steadily back in place. No "jerkiness", always higher than normal, never lower.
    Any ideas?
    "If you have integrity, nothing else matters. If you don't have integrity, nothing else matters." Alan K. Simpson.
    5spd E46 "3XX": 328i engine, 330i Intake and exhaust, CAI, 323i diff.
    Jul 2018
    Beaverton, Oregon
    1979 320i
    Bump because my E21 does the same. Just shows accurate or about an eighth or quarter lower.
    Sent from my SM-G955U using Tapatalk
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Fuel level senders are based on resistance readings. The arm sweeps across a metal grid with different resistance at each end. If the resistance of the grid, or the wire terminal, or the wire itself, or the plug into the back of the instrument cluster, changes resistance, then the wrong information is relayed to the gauge.
    The fault can be anywhere from the in-tank unit, to inside the cluster itself.
    On the E46, there is a cluster self-test which will show the amounts of fuel the cluster "sees" in each half of the tank. While this is a nice piece of data, it probably won't help you discern exactly where the data is erring.
    On the E21, I'd probably recommend replacing the sensor unit in the tank. While you're there, see if you see rust and crud in the metal tank.
    Chris Powell
    BMWCCA 274412
    Jul 2013
    Casablanca, Morocco
    2001 e46 323i
    Thanks Chris. I have tried unplugging the battery's negative lead for about an hour hoping that it would help getting rid of some random electric gismo. After plugging it back things are back to normal. I'll see how it behaves tomorrow.
    I do remember smelling some electric burnt smell twice recently. I had dismissed it thinking it was coming from outside or something, but now that I've had this issue and if it comes back I'll have look at the cluster (and perform the self test no matter what).
    Jun 2002
    E39M5, E500 4WD
    On E46 and later cars, disconnecting the battery does nothing more than resetting the clock.
    (Disclaimer: Okay, on MOST system vehicles, it makes the MOST system reboot and look for new modules...in case the TCU was replaced, for instance. This has nothing to do with E46's or with anything more important than the telephone.)
    For a burned smell, I'd personally look for oil on the exhaust, and a leaking valve cover. There's no way the fuel level measurement is causing a smell.
    Chris Powell
    BMWCCA 274412
    Jul 2013
    Casablanca, Morocco
    2001 e46 323i
    It was not an oil burnt smell, more like electrical wires/short circuit smell. Anyway I hope I get lucky on this one and that the gauge keeps behaving normally.
    I don't feel like chasing this thing around to find the cause and I'd hate to not know how much fuel really is in the tank.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Poke you head and your nose under the dash. Also, check the ground connection at the dash. As I remember it’s a knurled knob to the right of the steering column. The temperature gauge on my E21 was erratic (all others were fine). I flushed the cooling system, removed the radiator and cleaned it, all to no avail. Found the slightly loose ground knob. Fixed.
    Jul 2013
    Casablanca, Morocco
    2001 e46 323i
    Quote Originally Posted by MarcoZandrini View Post
    I'll try that, since the issue has unfortunately come back. I also noticed that on 3 occasions, the reading was fine right after unplugging the negative lead of the battery, but would get higher than normal a few miles later. I'm not familiar with electrical systems at all, but that makes me think disconnecting the battery could temporarily fix the issue by draining some "faulty" current or something.
    Thanks!
  1. Temperature gauge needle acting weird
    By lasmariaspr in forum 1991 - 1999 (E36)
    Last Post: 02-13-2011, 05:39 PM
  2. Gas gauge is acting weird
    By AZ330ci in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-09-2007, 11:14 AM
  3. MPG Needle Acting Weird
    By Wizzie944 in forum 1991 - 1999 (E36)
    Last Post: 04-09-2007, 11:13 PM
  4. Car Acts weird When i press on the gas
    By ERICKBOTIC in forum 1991 - 1999 (E36)
    Last Post: 11-11-2006, 03:05 PM
  5. 2nd gear is acting weird
    By XOC in forum 1992 - 1999 M3 (E36)
    Last Post: 06-16-2001, 11:23 PM
