Results 1 to 3 of 3
Thread: Tie Rod End adjustment, how much linner movent per turn?
    Jul 2004
    Rochester, NY
    '04 330xi, '53 MG TD
    Can somebody tell me with stock tie rod ends on a 04 330xi, how much change in toe in/toe out in inches will a single full turn of the rod yeild? Is one trun equal to one degree angle and the minuets are used for partial turns? I'm using plates to mesure my total toe and I need to take out 1/4 from each side. I don't think I can make the adjustment without going up on ramps and need to have some idea how much adjustment to make. Thanks.
    May 2010
    Honolulu, Hawaii
    '73 E9, '94 E34, '02 E46
    1. No.
    2. No.
    3. "take out 1/4 from each side" tells us nothing about what your current toe setting might be... especially if you don't know or state what the toe angel was to begin with.
    So either take it to an alignment shop or use a string between front and rear tires. And road testing.
    They say the cheapest thing about a BMW is the owner, but I don't believe that's true.
    Charlie
    Your mission, should you decide to accept it, is to add value to these threads, either by pictures or by descriptions, so the next person with the same or similar problem stands on your shoulders.
    Dec 2013
    Chicagoland area
    EXOTICS
  1. tie rod end adjustment?
    By aschroeder92 in forum 1975 - 1983 (E21)
    Last Post: 01-22-2009, 02:27 AM
  2. Aftermarket Tie Rod Ends?
    By ArcticFox in forum 1992 - 1999 M3 (E36)
    Last Post: 03-11-2004, 10:38 AM
  3. Tie rod end blew up! NEED HELP!
    By NegativeCambre in forum 1991 - 1999 (E36)
    Last Post: 06-16-2003, 08:07 PM
  4. Tie rod end or whole assembly?
    By Jack T. in forum 1991 - 1999 (E36)
    Last Post: 04-23-2003, 12:16 PM
  5. Tie rod ends or whole assembly easier?
    By M Rob in forum 1992 - 1999 M3 (E36)
    Last Post: 04-02-2003, 10:44 AM
