Shocks and camber plates are sold.
Springs - one pair of 0600.250.500 and one pair of 0600.250.800. Willing to sell each pair for $90.
Articulating rear spring perch - $230 new at GC, how about $200?.
High quality pictures available in the google photos album: https://photos.app.*******/Q3jP3YkqgdCEY8mBA
I’m selling a set of FatCat Motorsports custom-valved Bilsteins built for me by Shaikh @ FatCat. The build started with a set of used Bilstein PSS9 coilovers with about 1500 miles on them. The revalving and spring rates were set up as a configuration that would be at home with R-Comp tires and aero (splitter, wing) on track, and then street tires and A/C blasting on the ride home.
When FCM revalves the PSS9, the adjuster is disabled - these are no longer adjustable shocks. The custom valving more than makes up for the loss of adjustment. These have NOT been installed on my car since the revalve, but I had the good fortune of driving Shaikh’s personal car with a very similar setup - driving is believing!
Priorities have changed, and I need to focus on a new project. The kit includes the following:
- Custom-valved Bilstein PSS9 struts and shocks with perches modified to accommodate 2.5” springs
- Front spring rate - 500#
- Rear spring rate - 800#
- Ground control camber plates
- Ground control articulating rear spring perches
How long did they take to revalve? I’d like my Group Ns done. I need a bump down in rebound.
Did you ever sell these?
The Bilstein shocks are sold, along with the front helper springs and "mid perch". The springs, camber plates, rear spring perches are still available. I'll post up a separate ad for them.
pm'd on camber plates
Washedit1 by thedude60526, on Flickr11/10's Racing
94 325i #36/64 TEAM PENISTON OILS/ LARSENS BISCUITS
Camber plates are sold. Springs and rear spring perches are left. Yes, I've been lazy and not started a new thread yet
Are the rear articulating perches still kicking around? 2.5"? And do you have top spring centering cones to go with them? Cheers!
I do still have the perches . Yes they are 2.5" version, and believe you can see the spring centering cones in the picture - the perches are sitting nose down on them. Ping me in a PM if you're interested.
I've also sold one pair of the springs (the 500#), but the 0600.250.800 springs are still available.
Thanks,
Tom F.
