Results 1 to 7 of 7
Thread: Car overheats with no CEL or coolant leak
    Apr 2009
    FL
    '97 740IL
    The car drives fine but I do notice usually when I’m on idle for a few minutes it would overheat with a red warning saying to stop driving now. I’m assuming it’s my AUX fan or my radiator but I have no idea how to confirm, any idea? 06 750li
    Jan 2016
    Ca
    2001 525it
    Until you do a proper diagnosis and check for stored faults who knows what's happening
    Apr 2009
    FL
    '97 740IL
    Already ran diagnostics and didn’t show any faults in regards to this issue. I did run the AC and check under the hood, my AUX fan wasn’t running.
    Jan 2016
    Ca
    2001 525it
    Since the fan gets its signal from the dme I believe some body needs to figure that out
    Apr 2009
    FL
    '97 740IL
    Do you mean it doesn’t report it on the report? It was diagnosed with one of those $400 diagnostic tools that reads more than just basic codes
    Sep 2017
    Chicago IL
    1995 740iL
    Could be radiator fan clutch, simple fix you can do yourself. I had it happen on a e36 325i. My symptoms were car would overheat (temp gauge moving towards red) when idling or very slow driving in the city. As soon as I got on the highway / open road moving 40+ mph it would cool off and temp gauge would go to normal. You can test by sticking a few pieces of rolled up newspaper into the fan blades when the car is operating temperature and running. If the fan clutch is broken, the paper will stop the fan. Fan clutch is not expensive, it just requires 2 wrenches to remove, if you can change your oil you can do the fan clutch. I am not an RKI and my advice could maim or kill you (disclaimer).
    Markham, Ontario, Canada
    2001 750iL
    I think you already know the answer. If it only overheats on idle but not while driving then it definitely is the aux fan. It is PWM and full voltage will not trigger activation. Turn on the AC, the aux fan should run. Check the plug on the side of the fan for 12V, unlikely but it might also be the fuse. You can also put a scope on it to see if it is a square wave.
  1. Car tilted Down hill = Coolant leak?
    By 540i619 in forum 1996 - 2003 (E39)
    Last Post: 06-13-2007, 08:47 AM
  2. Head/car back together, immediate coolant leak :(
    By slopokdave in forum Forced Induction
    Last Post: 04-30-2007, 12:34 PM
  3. Coolant leaking, car smoking..
    By JL 325 in forum 1991 - 1999 (E36)
    Last Post: 04-23-2007, 11:36 AM
  4. coolant leak, overheats
    By e36 323 coupe in forum 1991 - 1999 (E36)
    Last Post: 12-01-2006, 03:04 PM
  5. help! car overheats; coolant won't drain from tank
    By RISK5000 in forum 1991 - 1999 (E36)
    Last Post: 08-02-2005, 08:20 AM
