Thought I would share this for group knowledge. On my last motor configuration I decided to try a stock gasket with no orings and S54 head studs just to see what would happen and what the limit on that would be. As you'll see below the limit was just about found. I pulled the head off today to make some motor changes and put in a cut ring gasket for safety reasons, and found the gasket was starting to push out on cylinder 2 and 5.
Just to recap the setup was a 2.8L built off a M50 block with stock bore wiseco pistons, 11.8:1 compression, stock headgasket, 11mm ARP head studs, and E85. The gasket is just a $30 victor reinz from amazon. I don't recall what the studs were torqued to but probably 100 or 110 ft lbs. It has a ton of passes on it at 28 lbs of boost and a dozen or so at 32 lbs. Probably about 800-850 whp.
Hard to see in the picture but normally the gasket is about a MM or so from the bore, but on cylinder 2 and 5 its about 3mm. Don't mind the clover leaf shape of the fire ring, they come that way stock to clear the valve reliefs in the chamber.
I don't know if it would have continued to push out and eventually fail, or mabey it would have stopped and stayed that way forever.
Very cool.
1989 535i - sold
1999 M3 Tiag/Dove - sold
Thanks for justifying me turning up the boost on my stock motor!
Just kidding. 12 psi will have to do for now.. once I have a spare motor I'll be sure to test the limits of a fully stock m52 (over 300k miles!)
1998 318i m52 swap 3.38 lsd, 1995 540i/6 speed (SOLD), 1993 325i, 1999 328is m-sport, 1996 328i GT35
is this from the power going on in the cyl or from the block/head flexing you think?
So you're saying that me running stock with normal ARP studs up to 450whp isn't really that big a deal like everyone was making it out to be for so long?
1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
I pulled apart a 600whp/550wtq block that had been together 2 yrs and ran fine. Every rod was s’ed
1989 535i - sold
1989 535i - sold
If the head and block are surfaced flat with a new stock gasket they will hold a lot. The blocks settle over time and develop high spots as the casting relaxes. If you surface a block they always have high spots around the head bolt holes.
yeah, this is the worst but at least 4 of the rods are bent. The piston is scuffed a bit on this one and the top ring is pinched but I think i can save it.
Rod from #5.
scuffs on the piston crown from bent rod. The piston mic'd out okay and I cleaned it up a bit but the rings were fucked up so I will have to order a new set for that cylinder
Piston #4 has a few detonation pits. The last pass at the track was at 32 psi and it almost went on the back bumper. I was too busy enjoying all the freedom to look at the gauges but the datalog said it was like 14:1 AFR the whole way down the track so I think the fuel pumps sucked air or something and it went way lean which is why it bent the rods and was pushing out the headgasket
I'm not to familiar with custom pistons and pins, but those pins look to have a large ID, like they are designed for NA? Any plans to beef them up?
WOT
cylinder 6 is cracked as well, just not as deep. Dang dude. lol
• Built S52 w/Dinan ISR-3 kit, NickG Stage 2+ Tune, Dinan Vortech V2 Supercharger, Dinan Air to Air Intercooler, Dinan CAI, Porsche 803 HFM, Buldogge 6" crank pulley, Griptec 2.90" blower pulley, Eurosport UD pulleys, Dinan 3.38 Diff, Dinan front/rear Swaybars, Dinan springs, Koni Yellow Sport Struts, Ground Control end links, South Bend Clutch Stage 3 Organic, AASCO Light Weight Flywheel 18.5#, Zionsville Radiator & Oil Cooler, Riot Racing BBTB, Schrick Intake Manifold, 42# Injectors, Schrick cams 264/256, Forged Wiseco pistons 9.0 comp., Forged Eagle rods, Supertech dual valve springs & valves, VAC crank & bearings, Supersprint mufflers, Euro Z3 midpipe, Raceland euro headers, Walbro 255, Bevauto ignition coils, Vortech Mondo bypass, Bailey Diverter DV30, Ireland Rear Subframe Bushings, Mason Engineering Strut Brace, Mason Engineering Clutch Petal, Apex 18" EC-7 Wheels, Full Custom Sound System, two trunk lids (with & without OE spoiler), Hardtop, Trunk full of AK's...
They are an off the shelf part number so no they don't have the thick pins and they have pretty thin rings also with a 1mm top ring, but they are a turbo piston. Where I really want to be is about 1200-1300 hp at the motor and I'm not convinced an M50 can ever do that reliably so I'm not sure I want to sink $2500 into custom pistons and good rods + machine work just to crack the block every 30 passes. Besides for the damage above, which I think is understandable for going down the track at 32 lbs and being dead lean, everything else in the motor seams to be doing okay. The bearings all looked like new and there was no wear in the pin bores. For the moment I am putting it back together with what I have and will keep the power in the 1000 hp range at the motor. Hopefully it will live for a season at that level and I can sort out where I want to go from there.
I have a 2-1/2 year old girl and we will be having another in about 2 months so I don't really have time to mess with this all the time anymore. I want to get into something that I can run a whole season at 1200 hp and not mess with, and by a whole season I mean like 150 passes because I run the shit out of this car. That was a major reason I went with the th400 trans. I don't think an m52 is up to it.
I think suitable motors would be a built 2JZ, a built S38, or a built LS motor. An S38 would be my top choice but they aren't making any more of them and they are already awfully hard to find and expensive. I would really need to buy 2 of them to have a spare. A 2jz isn't too bad to build to that level and most of my current setup like injectors, coils, turbo, torque converter ect would carry over. An LS motor probably make the most sense to invest in and if you blow one up they are everywhere for a couple hundred bucks. They are also pretty easily serviceable with reusable head gaskets and all that, and they make power at 6000 rpms so they don't need to be too exotic in the rotating parts and valve train. Plus I'm a v8 guy at heart. I don't know, we will see.
The moment you said you are not convinced the M5x will last, i knew its gonna be LS time. Lame.
For sure the most reasonable decision in the long run tho.
1982 E21 323i
M50B25 Turbo
Borg Warner S362 SX-E
ECU Master Emu
I thought the Elring gasket is supposed to be better than Viictor Reinz. Bigger fire rings or something. I am surprised it lasted as well as it did
Sucks to hear your giving up on the ol' m50. Makes rational sense though
The only reason it still has an m50 in it is they are cheap to make 800whp with and people seam to think it’s cool that it’s still bmw powered. Im sure you could make it live with billet caps and sleeves and a welded up head but I’m not willing to spend $15k to be cool when $3k in an LS gives what I want and can be replaced in a week. What’s lame to me is $1200 camshafts and $1000 harmonic balancers. I’m at the point where if I want to go faster I have to spend a bunch of money on top of what’s already been dumped in. I have $10k worth of transmission and drivetrain stuff. The car is good to go low 8’s high 7’s if it just had the right power maker in it.
The real problem is I didn’t anticipate how fast cars would get lol. I built the car to be a 800whp mid 9’s car, which it did. Problem is when started a 9 second street car was exrodinary, and when I finished it was the norm.
And if it was an s38 what would be the recipe for 1200hp ?
J Rod
but those guys from sweden make it look so easy to get ~1000 hp from these engines as long as you have the
money and the know how. With money anything is possible.
