Results 1 to 15 of 15
Thread: Fast blinking turn signal, bulbs are OK
    Feb 2012
    Southern Ontario
    93 850Ci, 2012 X5 35d
    My right turn signal blinks fast, rear bulb is OK, front bulb 5W is lit with parking lights and daytime running lights, the 21W circuit does not fire. The 5W circuit does fire, (which is odd, I would think it would just stay on steady) so I have a dim fast signal light. Can it be the relay?
    Sep 2010
    Corpus Christi Texas USA
    850ci, M5, Alpina B7
    There are no DTRL’s
    Feb 2012
    Southern Ontario
    The 5 W circuit of the signals, and the centre light in the strip run all the time on my car, I assumed they were the DRL...
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Only Canadian models had daytime running lights. Your turn signals are the on the outside edge of the lighting strips - the bulbs are single element 21W bulbs. The sidelight (double element 21W/5W of which only the 5W is used for the sidelight) should only come on with the light switch ON - the 21W element is used for the Canadian DRL's...
    My BMW Repair YouTube Channel
    Feb 2012
    Southern Ontario
    It is a C-Spec car, my outside edge bulbs are two element, 21/5W, the 21W is the signal, the 5W is the DRL, center light also has two elements, inner has an H3...
    radlaw's Avatar
    radlaw is offline SoCalEights Member BMW CCA Member
    Feb 2010
    Poway (San Diego), CA USA
    1995 BMW 840Ci
    Again, suggest getting new FTP harnesses (63118354385/6). Yes they are expensive; but at least you'll be doing it right, the way BMW intended. You'll have no "fast blinking" And no heat issues. Is your light switch a 4-position switch? Or refer to: https://www.bimmerforums.com/forum/s...&highlight=drl
    Feb 2012
    Southern Ontario
    Quote Originally Posted by radlaw View Post
    I've removed the resistors, and returned everything to stock, as BMW intended. I had the fast blink before, I thought I had blown a resistor, that's what started all this. So now back to stock, with normal bulbs, and still have it...I'm looking at the relay,
    -light switch is 3 position, off, parking lights, lights on
    radlaw's Avatar
    Feb 2010
    1995 BMW 840Ci
    Quote Originally Posted by Sundancer View Post
    When do DRL's come on?? With the parking lights? What country model is your car?
    Feb 2012
    Southern Ontario
    The DRLs come on when you start the car, with the switch in off. C-Spec car...Canada...
    Oct 2016
    Montgomery, AL
    '92 850i 6-speed (SOLD)
    I had an issue with my turn signals when I first got my car. They were flashing very slowly, so I replaced the signal relay and all was well. I'm no expert but perhaps your relay is acting up as well. It was only a $45 part. Unfortunately I don't have the part # as I sold the car and the paperwork went along with it.
    Sean
    Feb 2012
    Southern Ontario
    Quote Originally Posted by Sniff38 View Post
    Sean
    I have the part number, I tried to order one, $130, I'm going to a scrap yard to grab one, I'd hate to drop $130 and not fix the problem...
    Feb 2012
    Southern Ontario
    SUCCESS
    The flasher relay can be found in: 3 series 89-00, 5 series 87-96, 7 series 85-94, 8 series 89-99, Z3 94-02...I got one at a wrecker for $2...changed it, and success, all signals DLR etc work as intended...
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Hooray!
    Oct 2016
    Montgomery, AL
    For only $2 I hope you went back and pulled every relay out of that parts car and will store them on your shelf for future use.
    Oct 2008
    Mt. Dora, Florida
    CSi#18, Tesla S85
    Another possible simple fix. What light bulbs did you use when you replaced your bulbs? I have had similar situations happen in BMWs when replacing the bulbs. Make sure you use the type of bulb for European cars. I cannot remember the numbers, but for the same bulbs there are 2 actual numbers and bulbs. The non-European bulbs can sometimes cause a fast flashing situation similar to yours.
    Glad to see that you got a new flasher relay and it solved the problem.
    CSi #18 - Car & Driver Magazine 1994 actual test car
    -- Hellrot/Black-Gray (1 of 1 NA CSi color combination)
    BMWCCA E31 Chapter International Clubs Liaison
    North America Representative, 8er.or Board of Directors
  1. Very fast blinking turn signals?
    By jaredmac11 in forum 1975 - 1983 (E21)
    Last Post: 02-08-2019, 07:21 PM
  2. occasional fast right rear turn signal bulb
    By pbonsalb in forum 1996 - 2003 (E39)
    Last Post: 12-22-2009, 11:03 PM
  3. Turn signal bulb question
    By fattrapper in forum 2001 - 2006 M3 (E46)
    Last Post: 08-14-2002, 02:56 PM
  4. Part # for front turn signal bulbs?
    By VOLSBimmer in forum 1991 - 1999 (E36)
    Last Post: 05-01-2002, 07:49 PM
  5. New red LED 1156 turn signal bulbs blink super fast
    By daytonflyer53 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-25-2001, 01:13 PM
