Results 1 to 8 of 8
Thread: Overheating Issue
    Aug 2018
    Southern California
    1994 525i
    Overheating Issue
    Hi everyone,
    I have a 1994 525i thats overheating. After about 10-15 minutes of driving it begins to overheat and also leak coolant (which has always been an issue).
    The first thing I did was remove the thermostat but it still overheats. The second thing I did was replace the radiator. This made the car stop leaking coolant but it still overheats. The thermostat is good and so is the water pump.
    Now Im not really sure what it can be however, I did notice that the fan right behind the grill (not the radiator fan) is not working so I dont know if that might be the issue.
    If anyone has any idea of what may be causing the car to overheat I would appreciate any feedback.
    Thanks!
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to E34 forum
    May 2017
    Perth, Western Australia
    some
    If it's always had an issue leaking coolant than I expect your problem is very bad news - head gasket failure due to not fixing coolant issues sooner.
    The fan behind the grill is the auxiliary fan, mainly comes on with the a/c, or if it's really overheating (and would hardly ever come on in a normal working cooling system anyway), it runs off an electrical switch on the radiator on the side near the headlight - did you replace that switch or refit it to your new radiator? Anyway, it shouldn't be needed to run to help cool your car so it's not your main problem. The curse of long engines like an inline 6cyl is greater chance of head gasket failure and a leaking system with a bad radiator like your's apparently had normally means head gasket failure.
    Engine compression test, or pressure test your cooling system to verify if you have those tools or access to them. Otherwise let sit for a couple of days, take all sparkplugs out, turn the engine over and look for coolant/water coming out.
    Zionsville, IN
    93 740i, 84 533i
    Does the 525 have a clutched fan?
    Although you say it overheats after 15 minutes of driving, we don't know what type of driving? Highway speeds, or city speeds? If highway, then you have larger issues. If city or traffic, the non-working aux fan coupled with a week main fan will cause issues. I had this very scenario on my E32.
    Black on Black 740i - 10/92 build date, 225,000 miles.
    Delphin on Cherry 533i - 4/84 build date, 136,000 miles
    Black on Black 328i - 3/96 build date, 185,000 miles - Sold
    2008 Porsche Cayenne GTS
    NW suburban Chicago
    hiss by my window
    "water pump is good" How do you know this? The factory pumps with plastic impellor are notorious for a loose impellor, sometimes even intermittently.
    Are you actually overheating or is it over pressurizing?
    Failed HG is a distinct possibility.
    Aug 2018
    Southern California
    1994 525i
    Update:
    So it turns out I had a bad fan clutch. I was able to stop the fan with my hand. The radiator also had about a 3 inch crack. So I went ahead and replaced the radiator, fan clutch and also the water pump.
    After replacing the radiator, fan clutch and water pump I left the car on for about 20 minutes and the temp never went passed the half. I then drove it around for another 10-15 minutes and the temp never went passed the half. So I guess the problem is now solved.
    However, Im going to replace the valve cover gasket which leaves me with a new question:
    Fel-Pro or Mahle?
    Thanks for the feedback guys I appreciate it!
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Jun 2017
    SGV, Southern California
    1994 525i 5speed
    Might seem dumb but did you bleed the system according to Bentley’s?
  1. Newbie 84 318i overheating issue! help!
    By kakarotto in forum 1983 - 1991 (E30)
    Last Post: 01-25-2007, 06:54 AM
  2. Overheating issues
    By RedRum77 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-08-2005, 03:41 PM
  3. Overheating issue
    By ps525i in forum 1996 - 2003 (E39)
    Last Post: 03-30-2005, 01:55 PM
  4. 94 325ic M50 5sp Overheating Issue
    By Lizardkng in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-14-2004, 09:45 PM
  5. Help Overheating Issue.
    By JohnD in forum 1983 - 1991 (E30)
    Last Post: 08-30-2004, 03:16 PM
