Results 1 to 6 of 6
Thread: Valve cover gasket
    Mar 2018
    Washington DC
    2002 BMW 325xi
    Valve cover gasket
    How do you kno when you need a new one e30 any signs? Besides leaking oil
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    First see if bolts are loose. If that doesn't work then try new gasket.
    Mar 2012
    Hopewell Junction, NY
    1987 325iS...edan
    If the gasket is soaked in oil, it's no good.
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    unless its a rubber one. then just wipe it down and retorque.
    probably cork though so try tightening but plan on paying the 15 bucks and replacing it
    No e30s again.
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    When tightening valve cover gaskets, do not overtighten. Here is an article on valve cover gaskets
    https://www.pelicanparts.com/BMW/tec...alve-Cover.htm
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    You should probably replace it the next time you adjust the valves. I'm guessing here is that it should be soon.
    "Howdy, Folks!"
  1. Valve Cover Gasket Replacement
    By Stupacalypse in forum 1991 - 1999 (E36)
    Last Post: 08-09-2002, 11:20 AM
  2. Installing valve cover gasket need help!!
    By mrdoenutz in forum 1992 - 1999 M3 (E36)
    Last Post: 06-13-2001, 03:29 PM
  3. Installing valve cover gasket need help!!
    By mrdoenutz in forum 1991 - 1999 (E36)
    Last Post: 06-13-2001, 01:32 PM
  4. How to change valve cover gasket?
    By C///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-10-2001, 12:12 PM
  5. Replaced valve cover gasket
    By QuestMCoupe in forum 1991 - 1999 (E36)
    Last Post: 03-11-2001, 03:08 PM
