How do you kno when you need a new one e30 any signs? Besides leaking oil
First see if bolts are loose. If that doesn't work then try new gasket.
If the gasket is soaked in oil, it's no good.
Interested in vintage cars? Ever thought about racing one?
Info, photos, videos, and more can be found at www.michaelsvintageracing.com!
Elva Courier build thread here!
unless its a rubber one. then just wipe it down and retorque.
probably cork though so try tightening but plan on paying the 15 bucks and replacing it
No e30s again.
When tightening valve cover gaskets, do not overtighten. Here is an article on valve cover gaskets
https://www.pelicanparts.com/BMW/tec...alve-Cover.htm
You should probably replace it the next time you adjust the valves. I'm guessing here is that it should be soon.
"Howdy, Folks!"
