Resealed the intake manifold gaskets on my M70 when I got to the very end of the project I see this one wire sticking out of the boot of the wiring loom going to the cylinder 7 through 12 driver side to the throttle body assembly driver side. It protrudes from the side of the rubber boot close to the center of the engine we're all the fuel injector wiring harnesses run. it has a single wire connector to it and quite a bit of wire that looks like it's just been wrapped up and stuffed in there??? Where does it go?
this?
http://www.bimmerboard.com/members/o...nal/img194.jpg
http://www.nationalmedia.biz/images/...fyThisWire.jpg
That is for the case that you have a 2nd alternator, it is for the exciter wire to the cluster. If no 2nd alternator installed, just leave unconnected.
Thank you very much again Shogun. I followed the instructions on your website on sealing the intake manafolds and it worked perfect! She runs great! Thanks again!
