I was just looking at these Rogue Engineering Front Control Arm Bushings, anybody have experience with these?
http://www.rogueengineering.com/Rogu...E46_p_100.html
• Built S52 w/Dinan ISR-3 kit, NickG Stage 2+ Tune, Dinan Vortech V2 Supercharger, Dinan Air to Air Intercooler, Dinan CAI, Porsche 803 HFM, Buldogge 6" crank pulley, Griptec 2.90" blower pulley, Eurosport UD pulleys, Dinan 3.38 Diff, Dinan front/rear Swaybars, Dinan springs, Koni Yellow Sport Struts, Ground Control end links, South Bend Clutch Stage 3 Organic, AASCO Light Weight Flywheel 18.5#, Zionsville Radiator & Oil Cooler, Riot Racing BBTB, Schrick Intake Manifold, 42# Injectors, Schrick cams 264/256, Forged Wiseco pistons 9.0 comp., Forged Eagle rods, Supertech dual valve springs & valves, VAC crank & bearings, Supersprint mufflers, Euro Z3 midpipe, Raceland euro headers, Walbro 255, Bevauto ignition coils, Vortech Mondo bypass, Bailey Diverter DV30, Ireland Rear Subframe Bushings, Mason Engineering Strut Brace, Mason Engineering Clutch Petal, Apex 18" EC-7 Wheels, Full Custom Sound System, two trunk lids (with & without OE spoiler), Hardtop, Trunk full of AK's...
Looks like a nice part. Better than the delrin stuff thats out there.
Or go one step further.
https://slrspeed.com/products/bmw-ad...12122035126366
Stay OEM if you are street only. This just messes with noise and ride quality for a street car. You will not likely limit a good condition OEM CA bushing under normal or even spirited street use.
Dan "PbFut" Rose
These nearly solid-mount bushings are going to ruin your street ride comfort. If you desire an upgrade, I would suggest the "Street Performance" version of the Powerflex LCA bushings. You can go with the offset version to get more caster. You can order these through me, as I'm a retailer for BimmerWorld. Let me know if I can help. (email Anthony@DriveFasterNow.com)
http://www.bimmerworld.com/Powerflex...-PFF5-303.html
If you don't want to have to press or cut out your old bushings, you can get them already in the new lollipops:
http://www.bimmerworld.com/Powerflex...shing-Kit.html
-Anthony Magagnoli
#80 BMW M235i Racing - Pirelli World Challenge TC - 2017 Rookie of the Year
Rooster Hall Racing / FCP Euro
'87 BMW SpecE30 #007 - 2012 NASA SpecE30 NATIONAL CHAMPION
'08 BMW "130i" 6MT, '01 Z3 3.0i Coupe 5MT
'88 Pontiac Fiero GT 5MT (my childhood dream car!)
Send Your Teens to Street Survival
Drive Faster Now
I have heard powerflex LCAs had some issues at one point in time, plenty of posts on the e46 forums of people having them disintegrate. But looking at the rogue website for the e30/e36 they have street versions which have a metal surround with a polyurethane center. Why would that be considerably worse than Powerflex or AKG or any other polyurethane bushing, the portion that the control arm goes through is more or less the same. Just the surround is metal, which seems like a safer bet to me as far as potential failure goes.
The rogue bushings have an exchangeable inner portion anyways, since you can order replacement inserts on their own...
Suspension: Bilstein Sports, GC Coilover conversion, IE Subframe Bushings, IE RTABs, M roadster sways, M roadster front control arms, M roadster Front calipers/hubs.
Engine/Driveline: M54B30 intake Manifold, Dinan CAI, ZHP Cams, Headers, Underdrive pulleys, Conforti Software, 3.46 diff.
The metal in the bushing serves no purpose other than to reduce the amount of compliance in the bushing. I would not even recommend the Track Performance PowerFlex bushings for street use. I just put them in my Z3 and quickly realized that they were too much.
LCA bushings are a large contributor (or isolator) to impact harshness. Allowing wheel regression (rearward movement) upon impact significantly reduces the vertical acceleration and, as a result, harshness. Of course, it's a trade-off to steering response. I would recommend the Street Performance rates for a street-driven car, though. It's a significant upgrade to steering/handling/braking response, but won't be as abusive to you if you're driving on anything other than glass-smooth road.
-Anthony Magagnoli
Drive Faster Now
Powerflex have 2 different materials in their bushing range, purple for street use and black (stiffer again) for track use.
1999 2.8L Z3 Roadster,
2000 3.0L Z3 Roadster,
Bubba, may also help if you explain your intended use for the car. Daily driver, weekend canyon carver or dedicated track rats all have very different suspension needs
-Anthony Magagnoli
Drive Faster Now
Another option is to use the e36 M3 control arm bushing. M3 bushings are firmer than standard bushing (solid rubber vs. webbed design), but not as stiff as urethane. These bushings can be pressed in easily with a shop press.
I have run both power flex and M3 control arm bushings in e36/e46's and z3 cars. Both are an upgrade over standard. Ride quality ranking: stock > M3 > urethane > delrin > spherical bearing. Spherical bearing would be the most performance oriented by design, but have the least about of deflection over bumps. If you use urethane, grease them well...
Regards,
Brian
Cave Creek, AZ
